Old 28th October 2013, 06:02 PM   #1
thinreadline
thinreadline's Avatar
Default cannon ball ID
Can any members help me with any info about this item which I hope is some kind of cannon ball . It weighs 1.1 kg and is about 65 mm in diameter .
Old 28th October 2013, 06:16 PM   #2
Sure thing; more precisely a grenade. Cannon balls are solid, grenades are hollow, to be filled with explosives or shrapnel. The loading hole also fits a fuse. Early ones were simply matchcord and later ones were 'inteligent' devices, like detonators and timers.
This one was possibly for a 2 1/2" howitzer.
18th or early 19th century, i would say.
Old 28th October 2013, 06:21 PM   #3
thinreadline
Crikey Fernando , you are fast as lightning .... thank you so much for your rapid reply .... it will go well in my Napoleonic display then . One more question , if this is a grenade for use in a howitzer, how would it differ from a hand thrown grenade ?
Old 28th October 2013, 06:32 PM   #4
.... Crikey Fernando , you are fast as lightning...
That's what you will turn into, when you retire
.... it will go well in my Napoleonic display then ...
Yes, quite an indicated match.
.... ...if this is a grenade for use in a howitzer, how would it differ from a hand thrown grenade ?
Completely a different universe; in generation, shape, technology.
But don't be lazy; browse the Net
Old 28th October 2013, 06:39 PM   #5
thinreadline
Ah but I 'm not retired , any how, I will consider myself told off and go and browse the net. However I have to say that I prefer the wisdom of someone like yourself who I perceive to be an authority , rather than the unsubstantiated stuff one often encounters on the internet !
Old 28th October 2013, 06:52 PM   #6
Man, i know nothing; don't be surprised if someone comes after me and says i am wrong
I am comparing yours to mine; although mine is larger (51/2"), the approach is the same.
Old 24th May 2014, 04:16 PM   #7
Matchlock
Matchlock's Avatar
Hi there,
Unfortunately, it was only this morning that I noticed your query.
The piece in question is a cast iron grenade indeed, most probably 18th century, and was fired from a piece of ordnance.
Please also see my thread on incendiary objects and grenades:
http://www.vikingsword.com/vb/showthread.php?t=7085
Michael
