Old 16th September 2013, 08:08 PM   #1
Spunjer
Spunjer's Avatar
Default Slightly unusual Barung
sharing this neat piece...
not the usual type in regards to the shape of the handle. also, the ferrule is made out of braided brass wires, and closest to the blade is a solid brass piece. the matching scabbard is an art unto itself; meticulously carved ukkil on the mouth and tail. especially love the naga ukkil smacked in the middle. blade is an older style and is laminated. i believe Rick has a similar type.
please enjoy, and comments are certainly welcome
Old 17th September 2013, 01:59 AM   #2
A INTERESTING BARONG WITH SEVERAL UNUSUAL FEATURES. DO ANY OF THE FEATURES HELP YOU PIN IT DOWN AS TO LOCATION AND TIME PERIOD? THE CARVING IS DIFFERENT AND I AM NOT FAMILIAR WITH THE NAGA PATTERN YOU SPEAK OF. THE CENTER DESIGN AT THE THROAT LOOKS LIKE A LYRE (ANCIENT MUSICAL INSTURMENT) TO ME. THE FERULE BEING 5 OR 8 SIDED IS UNUSUAL AS WELL. NICE ONE
Old 17th September 2013, 03:13 AM   #3
Ron, do you think that the hilt is original to the blade? You also mention the "matching" scabbard. In the photos at least the wood of the hilt looks darker than the scabbard and i can't even tell if it is the same type of wood. I also don't see any motif from the scabbard that is repeated on the hilt so i don't quite see the "matching" thing. Frankly the hilt looks a little bit like someone outside the culture trying to mimic what they have seen on traditional barung hilts...or it could just be an oddball old hilt...
Old 17th September 2013, 05:15 AM   #4
ThePepperSkull
Beautiful, Ron!
Octagonal Moro hilts are something you don't often encounter outside of Pira, which is what first came to mind when I saw this.
Old 17th September 2013, 12:16 PM   #5
CharlesS
CharlesS's Avatar
Ron,
You already know I think this is a gorgeous piece of superb quality. I am a particularly big fan of the blade. Having seen it I feel very strongly that the scabbard and blade were "born together" as they are a perfect fit and look to match age-wise.
I cannot explain the rarity or reason for the unique nature of the octagonal Moro pieces, but we know they do exist, and the few examples seen seem to be of outstanding quality. Please see the pics below of a Moro spear with octagonal fittings discussed here some time ago.
Old 17th September 2013, 02:25 PM   #6
Thanks for that confirmation Charles. Sometime photos don't quite make things so clear.
Nice spear BTW. :-)
Old 17th September 2013, 02:55 PM   #7
Spunjer
Spunjer's Avatar
from time to time, we see these oddball weapons that bucked the conventional style. octagonal shaped handles does pop up every now and then. the relatively common octagonal hilts usually have a horse hoof pattern on the end.
David, three different types of wood were used on this piece. a darker type was used for the handle; meanwhile, the scabbard has a light and dark side (see pic below).
as far as whether the barung was "born with" the scabbard:
one way to check whether the barung was born with the scabbard was to dismantle the scabbard itself. every now and then the rattan bind are missing, so this is easily done. once it's dismantle, you can lay the blade on the notch carved out for it, and since each blade is unique, it should have that "Cinderella shoes" fit to it, meaning a perfect match. in this particular piece, the binds look original to the piece, so i won't go into that, rather i placed the blade on the scabbard just to show the clearance from the sides and tip. very, very tight. hope this helps...
vandoo, the "lyre" image is the representation of the naga head in ukkil motif. notice the similarity on this barung from artzi's website. as far as location/date: Sulu. date is harder to pinpoint due to lack of provenance, but i would conservatively place it around mid 19th c...
