Old 5th July 2005, 02:49 AM   #1
RobT
RobT's Avatar
Default Wooden Selut
Has anyone seen a wooden selut on a keris before? Attached are photos of a turned wood selut (perhaps kemuning) on a rather straightforward Balinese keris with a kocet kocetan hilt made of horn. If this is a traditional, albeit uncommon treatment, should it have a mendak also? The turning is carefully and well done. Due to the loose fit I don't think the scabbard is original to the blade.
Sincerely,
RobT
Old 5th July 2005, 08:02 AM   #2
Alam Shah
Alam Shah's Avatar
I believe it should have a mendak too. Looks nicer...
Click here for an example. Nice simple keris.
Old 5th July 2005, 01:39 PM   #3
Alam Shah
Alam Shah's Avatar
From the current pictures, it hard to determine the wood of the warangka.
If you could have a closer shot of the warangka with the wood grain visible,
maybe I can identify it.
Old 6th July 2005, 12:43 AM   #4
nechesh
nechesh's Avatar
Hi Rob,
Wooden "seluts" are not that rare, but i don't think this one belongs with this hilt. When i have seen them they usually allow for a jewelled ring to fit between it and the rest of the hilt. I have one like this, i'll see if i can get a photo up soon.
As for the mendak (uwer), i also think a keris like this looks better with. It seems a lot of Balis show up without them, but i don't believe this is by design. A mendak completes the ensemble.
Old 6th July 2005, 03:47 AM   #5
RobT
RobT's Avatar
Default Thanks for the info
Alam Shah,
Wranka close up coming up.
Nechesh,
I would really appreciate any photos you have.
Thanks to you both. I'm so happy that the wooden mendak is appropriate. I really like it.
Sincerely,
RobT
Old 6th July 2005, 04:03 PM   #6
Alam Shah
Alam Shah's Avatar
Default sheath material...
IMHO, the balinese warangka gayaman is made of timoho wood (Kleinhovia Hospita). The gandar is made of timoho pelet wood.
Old 7th July 2005, 02:16 AM   #7
RobT
RobT's Avatar
Default Good to Know
Alam Shah,
Thanks for the info. I keep a brief description of all my blades and I will add those wood names to this. Another nugget of knowledge to put into my small (but growing) hoard to be applied in future blade analysis.
Sincerely,
RobT
Old 8th July 2005, 08:54 PM   #8
nechesh
nechesh's Avatar
Rob, here's my Bali hilt w/a wooden "selut" (i'm sure it's called something else. Anyone?). As i stated before, the bottom and top pieces fit together so as to allow a space for the hilt ring (there is probably a name for this as well) to fit inbetween. I think yours may have belonged to such a hilt. It doesn't seem to really fit with the horn hilt you have now.
Old 9th July 2005, 04:09 AM   #9
RobT
RobT's Avatar
Default Resolution Obtained
nechesh,
Perhaps you have supplied the complete solution. I have wondered why the kocet kocetan hilt didn't fit the selut well. I think that, with the addition of that large metal ring (uber mendak?) between the hilt and the selut, the fit will be correct and the addition of a mendak below the selut will complete the ensemble. With the picture you posted as a guide I will see what I can do to get the necessary metal fittings made up. Thanks a million. You provided the information needed to get me on the right track.
Sincerely,
RobT
Old 9th July 2005, 02:08 PM   #10
nechesh
nechesh's Avatar
Hey Rob, that's the same track i followed with this hilt. I think these rings and mendaks often go missing on Bali pieces because they are often made of precious metals and at least low grade gems that people can sell off. I got this hilt without this ring, but it was obvious it had one. A cilinder from the top fit into the bottom leaving a groove for the ring to ride in. So i had this ring commissioned by our own Battara. I gave him a lot of trouble making this ring right but i'll bet he would be willing to do the same for you now that he's had a bit of practice making them.
