Old 10th December 2008, 09:46 AM   #1
Michel
Default A thai Dha ?
Can any Dha lover analyse the attached pictures and give an opinion?
I am totally incompetent in the Dha world, but think that this dha is from thailand,
blade is : 57 cm,
grip 31.cm,
blade thickness at the grip : 9.3mm,
width of the blade at its max: 26.6 mm.
Sheath in wood with very fine rattan binding.
Thanks for any information.
Michel
Michel is offline   Reply With Quote
Old 10th December 2008, 01:46 PM   #2
Andrew
Andrew's Avatar
Shan, probably from northern Thailand.
Old 11th December 2008, 08:19 PM   #3
Mark
Mark's Avatar
Default Yep
What he said.
Old 11th December 2008, 10:46 PM   #4
Michel
Default A Shan Thai dha
Thank you Andrew and Mark.
XX century probably ?
I am hesitating if I should do anything on the blade or the sheath or just leave it as it is.
Thanks for your opinion.
Michel
Old 12th December 2008, 02:17 PM   #5
Mark
Mark's Avatar
Any time.
I think it is 20th C., though it looks fairly old, so perhaps the first half of the century. As for restoration, I would just clean off the active rust and oil or wax it. Originally it would not have had a high polish, though if you see evidence of lamination or edge hardening you might consider having one side poilished to reveal that.
