Old 20th November 2018, 10:53 PM   #1
qusko
Default Ottoman karabela XVIII
I have bought following Ottoman karabela, which I think is from XVIII century.
Similar item is in Dresden museum (https://skd-online-collection.skd.mu...s/Index/289073) with following differences:
- hilt and crossguard
- blade in my item is more curved
In some other posts I've found it can be precursor of pala.
It also has a form of polish karabela type IIc, but ottoman origin.
Hilt with the blade is a little bit not typical..but possible
Can you share your opinion?
qusko is offline   Reply With Quote
Old 21st November 2018, 06:36 PM   #2
Kubur
Kubur's Avatar
Your sword is superb
I think you are right, its an Ottoman pala with a karabela hilt.
18th c. at least for the blade...
You should clean the silvers fittings and guard.
Congrats
Old 21st November 2018, 07:08 PM   #3
Yes; a superb example indeed .
Old 21st November 2018, 08:12 PM   #4
qusko
Congrats
Thanks
I like it very much and indeed some cleaning is required.
About the blade I have similar opinion that it's XVIIIc. I am just not sure if the rest (hilt/scabbard) is from the same period (despite all matches very well)
Old 22nd November 2018, 12:13 PM   #5
Oliver Pinchot
Nice example. In Turkish museums, these short, broad blades are identified as
naval.
Old 22nd November 2018, 02:14 PM   #6
Would not be surprised to see wootz blade. Pattern-welded at the very least. Etching a small window will give an answer, but it would be an easy task: no rusting, no pitting. Not sure about the fittings: on the photograph they look copper alloy to me. Again, a small area rubbed with silver-cleaning paste would direct you to their full cleaning or leaving them as is.
Outstanding example of a true museum quality! Congratulations!
Old 22nd November 2018, 03:20 PM   #7
rickystl
While mostly a novice with blades, I just want to comment what a beautiful sabre this is. Outstanding looks. Congratulations.
Old 22nd November 2018, 08:39 PM   #8
qusko
Thank you Ariel!
For the feetings for sure it's brass.
Old 23rd November 2018, 04:40 PM   #9
Then do not touch them!
Shiny brass is vulgar, your patinated one is old, mellow and classy.
Old 23rd November 2018, 05:46 PM   #10
Kubur
Kubur's Avatar
Originally Posted by qusko
Thank you Ariel!
Well i'm 99% sure it's silver, you should try in one small corner, on the non exposed face of the sword... Many people do this mistake old silver looks like brass sometimes.
I agree with Ariel if it's brass don't touch it.
