Old 11th July 2007, 03:10 AM   #1
Default Outstanding Georgian Shamshir
Just ended.
http://cgi.ebay.com/ws/eBayISAPI.dll...1332&rd=1&rd=1
Why Georgian?
Look at the handle: it widens up toward the crossguard. This is a typical Caucasian (Georgian) feature; Persian Shamshirs had handles of uniform thickness.
Also, the image of a wolf on a crossguard: very Georgian, too. Whether the crosses on the other side of the crossguard are of religious or a decorative character is uncertain.
Beautiful mechanical damascus: almost parallel lines near the edge and wildly wavy towards the back.
Question: is there any mechanical preference where to put lines vs. waves?
Old 11th July 2007, 05:33 AM   #2
Jeff Pringle
Jeff Pringle's Avatar
Not so much a mechanical preference, it is a natural outgrowth of making the blade from a layered piece of metal. Forging induces waves of various sorts in the layers, which makes the sides of the blade look wave-y. It is usual to leave the edge fairly thick so it will withstand quench-induced stresses better. Once the blade is heat-treated, the edge is thinned down to where it will cut and this abrasion cuts across the layers, revealing the lines along the edge. You can tell how close to shape a blade was forged by how wide the zone of lines is. The effect is visible on wootz blades as well. There are ways of getting around the effect, but for most ethnographic blades the maker was not worried about it.
Old 11th July 2007, 09:16 AM   #3
Jeff, have you looked at the pics?
Ariel was asking about the pattern towards the back of the sword. The pattern there seems to be intentional and probably manipulated by the bladesmith to make it look prettier.
BTW, any guesses how risky it would be for the koftgari to remove the active rust present on the fittings?
Did you win this, Ariel?
Old 11th July 2007, 12:10 PM   #4
I did not bid. Even though it is gorgeous, I want one with a scabbard. High maintenance
Old 11th July 2007, 02:01 PM   #5
ward
I find it extreamly doubtful that wolf was part of the original sword. probaly a 21st century addition. The rest of the sword is pretty questionable
Old 12th July 2007, 12:48 AM   #6
I looked at it today on a better screen: you might be right about the wolf
However, I am wondering what made you question the rest of the sword? Looks perfectly fine to me. Please explain.
Old 12th July 2007, 02:24 AM   #7
ward
the grips do not look correct or the rivets. also with the active rust especially inside the crossguard would not be suprised if the whole hilt was new then dipped in acid and let air dry. Anything coming over the internet from georgia is pretty questionable in the 1st place.
