Old 7th June 2007, 06:49 AM   #1
Jeff Pringle
Jeff Pringle's Avatar
Default Pamor question
What would you call a pamor that looked like this:
Old 7th June 2007, 01:05 PM   #2
Could we see the entire blade Jeff ?
Old 7th June 2007, 04:24 PM   #3
cahaya
cahaya's Avatar
Hai...
the pamor for me: is more like ganggeng kanyut
cahaya
cahaya is offline   Reply With Quote
Old 7th June 2007, 10:21 PM   #4
Raden Usman Djogja
Raden Usman Djogja's Avatar
Is that a keris? Jeff, please show it completely.
Raden Usman Djogja is offline   Reply With Quote
Old 8th June 2007, 02:44 AM   #5
Question
The spots on the filed edge are something new to me.
Where's the core?
Is this blade all pamor?
Old 8th June 2007, 03:00 PM   #6
Jeff Pringle
Sorry for the confusion, no this in not a keris, but a test I did to see how a specific keris pamor is created. The spots along the edge are a transient phenomenon, related to air bubbles sticking to the blade in the quench, and should be ignored, if possible. Only the center of the blade is patterned.
I don’t know about you guys, but when I see a pamor one of the things I start to do is try to figure out the sequence of forging operations that lead to the various patterns, and that discussion of Walang Sinudhuk ( http://www.vikingsword.com/vb/showthread.php?t=4577 ) a couple weeks ago got me wondering about it and a couple closely related pamor - at least, closely related in terms of how Tammens drew them – were created. The discussion brought up various drawings that were more or less clear from a “finding out the process” perspective, but two very different methods are clearly implicated, one in the first couple drawings and the photo I found (which look very different, but which all imply a particular metal manipulation), and a second in the rest. Ganggeng kanyut looks as if it was made by a different process as well, so if that is what this pattern is saying, I’m way outside the ballpark, in my estimation of how the pamor metal gets manipulated to create walang sinudhuk. I’m also curious about how walang sinudhuk and dadung muntir are related, since they should both be pamor over a core steel, correct? How are they different, in your opinion, and/or which references give accurate depictions of them?
But I think I muddied the waters by using fewer layers, and doing more cross-wise forging than you’d typically get in a keris, so the pattern is stretched in a way that makes it look less like the target pattern I was going for.
Old 9th June 2007, 05:46 PM   #7
Marcokeris
Marcokeris's Avatar
Jeff
your pamor is like this western damasc (the picture is from the spectacular book damascus steel by M. Sachse)
Old 9th June 2007, 06:34 PM   #8
Arrow
I know that this will probably sound stupid; ,but couldn't one try to figure out pamor types by trying to produce them with polymer clays of contrasting colors?
It would save a lot of fuel for the forge .
Old 9th June 2007, 07:27 PM   #9
lemmythesmith
lemmythesmith's Avatar
I've used childrens modelling clay to work out Damascus patterns many times, the trick is to put the "billet" in the fridge so when you cut into it to produce the patterns it doesn't smear into itself. Pamor development from the comfort of your armchair!
lemmythesmith is offline   Reply With Quote
Old 10th June 2007, 04:57 AM   #10
ganjawulung
ganjawulung's Avatar
Default Kupu Tarung and Lar Gangsir
Hi Jeff, Lemmi and All,
I'rather call jeff's pamor as "lar gangsir" (mole cricket's wing). Compare with the 2nd photo below. And not the "kupu tarung" (fighting butterflies) in the first photo... Did you make it machinally? Or handmade, Jeff?
Ganjawulung
Old 10th June 2007, 08:14 AM   #11
Jeff Pringle
Really? In what way? What similarities do you see?
Sachse's book is a great overview of patterned steel, he really did a great job of hitting most of the historical and cultural patterned steel touchstones.
couldn't one figure out pamor types by trying to produce them with polymer clays of contrasting colors?
Hey, if I wanted to be a ceramicist, I'd work with clay, alright?!?
I have used this method, but really, it's more fun to do it in steel.
Ganjawulung - it is hand-hammered, but interestingly, the first photo you posted looks to be made the same way (or rather, in a similar way - there is an additional operation going on in the kupu tarung, perhaps, but both are based on twisting twisted bars together, from the look of it) as my test piece, the second not. I definitely think forging in the double-fuller has confused matters, and will have to make up a bit of steel with more layers, and make it into a blade that is shaped in a more traditional keris way to get a clearer read on the pattern...
Thanks for all the input!!
Old 29th June 2007, 04:40 AM   #12
Megat_Alam_Syah
Megat_Alam_Syah's Avatar
hi! i'm new to this forum and also new among the classic weapons enthusiast. i'm from the state of terengganu and recently visit a distant relative who happen to own a keris. it was handed down for generations from father to eldest son. he show me the keris and from there my interest grew. though i came from the land where the keris orginated, i shamefully say i know almost nothing about it and i'm amazed at many of forumers here who, from distant land, knows more about keris then many of us here in Nusantara.
i have a question about pamor. is it possible to create a certain design, say an inscription or something using pamor, or is the pamor design are happen to be by chance?
Megat_Alam_Syah is offline   Reply With Quote
Old 29th June 2007, 08:33 PM   #13
Weclome to the forum Megat Alam Syah. I encourge you to make use of this forums search feaure. I am sure you will find many old threads to interest you.
The answer to your question is yes it is possible and i believe that an example was recently posted so take a look in the recent threads...or maybe that person would be so kind as to provide a link or repost the picture.
Old 30th June 2007, 12:44 AM   #14
Alam Shah
Alam Shah's Avatar
Originally Posted by Megat_Alam_Syah
... i have a question about pamor. is it possible to create a certain design, say an inscription or something using pamor, or is the pamor design are happen to be by chance?
Hi Megat, welcome to the forum... I suggest you look up these...
pamor tiban, pamor rekan,
pamor mlumlah, pamor miring...
Also have a look at "Keris in the Malay World" (in VCD format), by
Kuala Lumpur: Dept. of Museums and Antiquities, Ministry of Culture, Arts & Tourism, [2002]
In the videodisc, there are segments on how pamor inscriptions are made.
These should get you started...
Old 2nd July 2007, 01:33 AM   #15
Megat_Alam_Syah
i'll check it out. thanks!
