Old 19th March 2007, 07:42 PM   #1
lelang69
Default Keris Ganyaman Solo
dear list,
need comment of this:
Keris ganyaman solo, warangka kemuning wood with Brass pendok slorok. the blade is 7 luk. ukiran hilt solo solo yudo winatan.
thanks
lelang69 is offline   Reply With Quote
Old 19th March 2007, 08:21 PM   #2
The sheath in ladrang, not gayaman. Looks to be iras (all one piece).
(Edit) Actually on second glance i see you wrote "ganyaman". If that is not a typo (i.e. meant to read "gayaman") then i am not familar with the term and withdraw my comment.
Old 21st March 2007, 08:53 AM   #3
lelang69
please deh !
ada komentar yang lainnya ( Is there any comment exept david)
The Pamor Kaleee....!.
or the blade gitu loh.......!
so anyway Thanks david for the comment
Old 21st March 2007, 06:36 PM   #4
Lelang, more than half the words you have written here do not appear in the Indonesian dictionary. While i realize English is not your first language i am afraid i must insist that you post in that language just so we all understand each other.
I remain confused as to whether or not you intended to write "gayaman" when you wrote "ganyaman". Could you clarify please?
Old 21st March 2007, 06:44 PM   #5
lelang69
David. this only a joke. yes I know the expresion is make you and list confuse. Do you have any comment about the pamor and blade.
please welcome other list for the comment
thanks very much david
Old 22nd March 2007, 07:06 AM   #6
Alam Shah
Alam Shah's Avatar
Hi lelang69,
I do not know much about keris, but here goes...
The sheath is a Surakarta styled Ladrang form. It's definitely not gayaman/ganyaman. The wrangka is gandar iras, as mentioned by David.
(There seems to be a large split/crack/break along the vertical line of the wood grain, I guess). The oversheath (pendok) is pendok blewah. The hilt (ukiran/jejer), is in the Surakarta Yudowinatan form (as mentioned). The hilt ring (mendak), is a bit too small and not of known Solo/Surakarta form. The blade's luk form is fashioned in the style of luk Kemba (gentle waves). The blade tip (panetes), is nyujen (narrow tapered point). I hope it helps.
The blade and pamor looks nice.
I'll leave it to the more knowlegeable members to comment.
The pictures are blur, dark and small. The angle of which it were taken doesn't help either.
Old 23rd March 2007, 06:32 AM   #7
lelang69
dear Pak Alam syhah,
Terima kasih thanks, It's very helpfull, Is it the woswutah pamor or what.
may be you can explane it Thanks. also welcome for the list comments
thanks any way
