Old 11th March 2007, 08:21 PM   #1
FenrisWolf
FenrisWolf's Avatar
Default New arrival -- Pulwar from Afghanistan...
...by way of Germany, so it's been on a bit of a journey. 4 1/2" hilt, blade is 29" in straight line from quillions to tip, quillions 4 1/8" wide, blade is 1 5/16" wide at hilt, 5/16" thick at spine.
Blade is clean except for a few spots ofactive rust along the cutting edge that I will carefully remove to prevent any further deterioration. Whoever did the polish/etch on this did a really nice job of bringing up the pattern without over-polishing the blade. Never really understood the expression "watered" steel before, but the pattern weld on some of these blades really does look like running water...
So, any opinions from the experts? Was the seller accurate in attributing this to Afghanistan, and any guesses as to approx. age?
FenrisWolf is offline   Reply With Quote
Old 11th March 2007, 08:29 PM   #2
ward
Afghanistan is right, Indian pattern weld blade 19th century chiselling on basket will pop out more if you clean it
Old 11th March 2007, 09:04 PM   #3
FenrisWolf
FenrisWolf's Avatar
It actually looks better in person; I don't have the best camera in the world, nor the best photographic skills. Here are a couple of other shots of the hilt. There are also faint traces of the gold koftgari that once decorated it, but they'r almost nonexistent.
Old 11th March 2007, 09:09 PM   #4
ward
that is probally brass were the piece was welded together. As a general rule you will not see gold on afghan pieces.
Old 11th March 2007, 09:32 PM   #5
FenrisWolf
FenrisWolf's Avatar
Ah, that makes more sense; it didn't really look like the sort of traces that old koftgari leaves, but I couldn't think of what else it might be. Thanks!
Old 11th March 2007, 09:41 PM   #6
Andrew
Andrew's Avatar
Congratulations, Fenris. That's a very nice sword. I love the patina on that handle; contrasts very nicely with the blade.
