Old 2nd February 2026, 10:49 PM   #1
DaveA
DaveA's Avatar
Default Nepalese Tulwar-hilted Kukri or ???
Hello All,
I won this weapon at auction yesterday. It was advertised as a "Sussun Pata Khanda" but I think it is not. The shape nearly matches the Nepalese Kukri with a Tulwar hilt discussed in this thread from 2009. Decoration is nearly completely lacking. I draw your attention to the spine which is T-shaped as one finds on weapons such as the Khyber Salawar. It seems like it could be a hybrid from the India northwestern frontier.
I do not yet have the weapon in hand so there is not much more I can tell you. The overall length is reported as 23 inches. The provenance is listed only as "New York City Estate."
What is your opinion on type(s), origin and possible age?
- Dave A
Old 3rd February 2026, 12:55 AM   #2
RobT
RobT's Avatar
Default Not Exactly A Tulwar Hilt
DaveA,
I have read that this type of hilt is called an Indo/Moslem basket (as opposed to the Hindu basket hilts commonly found on firangi). I think these hilts are rather uncommon. Aside from photos, the example I have (from eBay 2005) is the only one I have ever seen. The seller said that he found the piece in an abandoned house in Georgia which was in an area slated to turned into a man made lake. The blade (very badly pitted) that came with my hilt is only 21.25” (53.975 cm) long and, since it was completely loose in the hilt when I got it, I can’t be totally sure that it is original to the piece. The straight blade has a 4.25” (10.795 cm) false edge and one broad and very shallow fuller which fades out at the foible where the false edge begins and also fades out at the base of the blade. The tang is the same as what would be found on a typical tulwar blade. That the fuller doesn’t run off the blade on either end indicates that it hasn’t been shortened. As it is with both yours and mine, all of the pictures of blades that I have seen with this type of hilt, have been short.
Sincerely,
RobT
Old 3rd February 2026, 03:28 AM   #3
DaveA
DaveA's Avatar
Thanks Rob. I am sure glad that your blade was rescued before the lake flooded it. The Georgia reference will send me to my reference books. I have become very interested in the Caucasus since it represents one of the great geographical points where nations clashed. Interesting weapons often arise in such places.
Do you have any picture you can share?
My hilt resembles a khanda, but the protrusion above is too short to offer a second grip like a khanda.
Dave A
DaveA,
Sincerely,
RobT
Old 4th February 2026, 01:29 AM   #4
RobT
RobT's Avatar
Default Not That Georgia
DaveA,
My bad. I should have been more clear. I meant the USA state of Georgia. I will post pictures of mine tomorrow. Your hilt (and mine) does not really resemble a khanda (or a firangi for that matter) because the quillons are totally different and, as you pointed out, the pommel spike is too short to provide a two hand grip. Also, the grip on khanda and firangi hilts typically lack the center bulge found on tulwar hilts. Even when a center bulge is present on khanda and firangi, it is less pronounced than on tulwar hilts. If you compare your hilt to a tulwar hilt, you will see that your hilt is basically a tulwar hilt with a basket on it
Sincerely,
RobT
Old 4th February 2026, 05:46 PM   #5
RobT
RobT's Avatar
Default Photos of Mine
DaveA,
Here are pictures of mine. As I said in my previous post, the blade is 21.25” (53.975 cm) long with a 4.25” (10.795 cm) false edge. The spine at tang is 3/16” (4.7625 mm) thick with no distal taper until the false edge.
Sincerely,
RobT
PS: The front shot of the hilt does look like a frilled lizard displaying, doesn’t it.
Old 4th February 2026, 11:54 PM   #6
DaveA
DaveA's Avatar
Rob,
Yes. I still have the occasional “Jurassic Park” nightmare!
Thanks for your comments.
Dave
Old 5th February 2026, 10:35 AM   #7
Kmaddock
Kmaddock's Avatar
Hi
see my similar example in this post
http://www.vikingsword.com/vb/showthread.php?t=26653
Ken
Old 5th February 2026, 06:59 PM   #8
DaveA
DaveA's Avatar
Ken,
Just to clarify, you are saying that the weapon I showed is a Sussun Pata , not a khurkuri? Thank you for the link.
Dave A.
Originally Posted by Kmaddock View Post
Hi
Ken
Old 5th February 2026, 07:13 PM   #9
Here is an example of what is basically the same hilt mounted on an extreme Kirach blade.
Old 5th February 2026, 09:49 PM   #10
RobT
RobT's Avatar
Default Cutlass?
DaveA,
Kmaddock’s blade is a sossun pata, yours isn’t. AFAIK, it’s a matter of length vs breadth. The sossun pata is more yataghan-like. Your blade is more khukri-like.
Rick,
That is one heck of a beautiful blade…on a rather rare hilt to boot. All the examples I have seen of swords with this type of hilt have had relatively short blades. What is the length of your blade?
Just a thought (based on no evidence whatsoever). A short blade mounted on a hilt with a knuckle bow would make for a good shipboard weapon.
Sincerely,
RobT
Old 12th February 2026, 02:34 PM   #11
Yes, it is unusual, Rob. I've never seen one like it.
The blade is 26 inches long, and 1.5 inches wide.
In the interest of full disclosure our own Battara made the silver chape for me to protect the scabbard tip.
Old 12th February 2026, 03:25 PM   #12
RSWORD
RSWORD's Avatar
The wide blade with deep curve is similar to Indian swords with the name "Ox-Cutter". There is an old forum thread that discusses these pieces. Your example is a smaller, but similar blade style to these swords. Several examples are given in the thread.
http://vikingsword.com/vb/showthread.php?t=4061
Old 16th February 2026, 11:43 PM   #13
DaveA
DaveA's Avatar
Default ox-cutter
Thanks, this was a good lead. Unfortunately, all of the links in that thread are dead. I'm seeing that more and more,
My sword feels more like it is more suitable for an ox beheading than running around a battlefield. Way to big and heavy for most people to wield it like a kukri
Dave A
