Old 23rd August 2025, 08:28 PM   #1
drac2k
Default Inuit Adze or Tool ?
I recently procured some items that were listed as "Inuit Root Diggers," and that made sense, however when I got the items, they were quite large, especially the Adze.I haven't seen( my knowledge on this subject is even more limited than that on others), any Eskimo implements this large and as such I was wondering if they could belong to any other group of people?
They seem to be made of whale or walrus bone.
The largest piece measures 20" x 4".
Old 25th August 2025, 04:14 AM   #2
I can't figure out why the fish bone part has so many cuts and holes, perhaps it's a multi-use tool which would make sense in a semi nomadic culture in the time period it came from.
It looks very very old.
Old 25th August 2025, 01:29 PM   #3
drac2k
My theory is that there was a wooden haft that went through the middle of the heavy hoe shaped implement and that it was lashed onto the shaft, through the cleat, pulling it down, locking it to the handle and securing it against any downward strikes.This is just my guess, not based on anything.
The only hole that goes all the way through is the one for the handle.
Old 25th August 2025, 02:07 PM   #4
If you can tell if they are bone and not ivory they could be from Tierra del Fuego. The side lashing I believe is more of a South American method rather than Inuit. Just a suggest no expert. They are a rather cool collection of artifact and if from Tierra del Fuego I would think them rather rare too. Inuit ice axes.
Old 25th August 2025, 07:14 PM   #5
drac2k
From my view,I definitely believe them to be bone.The lashing looks like it could work on my piece, the only exception is that my implement has a provision for a haft to be inserted inside it whereas the examples you provided,I believe are laid on top of the handle and lashed onto it.
Old 26th August 2025, 12:51 AM   #6
I think Drac's item is Walrus Ivory. I only used Fish Bone as a euphemism for the material. If you look at the end that is narrower, where it is cut, you can see the dentine core of the tusk.
Old 26th August 2025, 03:08 AM   #7
drac2k
Rick, are you talking about the smaller piece or both of them?
Old 27th August 2025, 03:32 PM   #8
I'm getting a bit confused here, there is only one piece of Bone/Tusk, correct?
At the narrow end where the square hole is, if you look where the narrow end is cut off, the end grain seems to show the dentine as a different pattern as seen in the picture below.
While doing a bit of a search for like tools, I came across a picture of very similar Inuit items. All of the descriptions of these were identified as petrified tusk. I should have saved the photos, but I didn't. Maybe an image search for Inuit ice axe will provide the picture again.
https://walrusivory.org/wp-content/u...py-980x784.jpg
Last edited by Rick; 27th August 2025 at 04:26 PM. Reason: not enough coffee, or maybe too much
Old 28th August 2025, 05:24 PM   #9
drac2k
With the exception of the wooden handle, there are 2 pcs. that are either bone or tusk.
