Old 11th October 2024, 09:42 PM   #1
MARW
Default Epoxy for restoration
Hi all. I am confused as to what to use while repairing antiques. I am usually concerned with shamshirs where you have to fill in the guard with some material. Traditionally, a whitish glue was used, as explained in the paper by Dr Khorasani. I have been told by a lead restorer that he will use epoxy as a filler in the guard. To me, it seems a very non reversible fix. Any thoughts?
MARW is offline   Reply With Quote
Old 11th October 2024, 10:47 PM   #2
Interested Party
Interested Party's Avatar
Try searching "cutlers resin"
Here is a good thread to start with. Look at post #19
http://www.vikingsword.com/vb/showth...=cutlers+resin
Last edited by Interested Party; 12th October 2024 at 02:56 PM. Reason: Forgot attachment
Old 12th October 2024, 02:45 AM   #3
werecow
werecow's Avatar
I think this post is missing a link.
Old 12th October 2024, 02:57 PM   #4
Interested Party
Fixed.
Old 27th October 2024, 01:24 AM   #5
ausjulius
Don't use epoxy or modern glue on any antiques. Also epoxy is inferior and will quickly work loose on swords.cutkers resin or jewellers resin is easy and cheap to make, very strong and can be removed when needed.
Easiest way to make it is with Shellac or pine resin, wax and a filler like brick dust, sand or clay dust, charcoal dust, baking soda.. . The Japanese recipes contain rape seed oil as I presume historically bees wax was rare there (was a major import prior to the industrial age) the oil and wax makes it softer and more flexible. It's very useful to reattach handles, chapes and other components.
There is a technique to using it and temperature is very important.
If you wish for example to fit a chape the chapel itself should be warm . But if you want to attach a stone spear head i the wood and the stone should be as cold as possible.
The white substance you mention was probably alum mixed with some fillers and other materials .
The guards of some shamshir and the tulwar are held on alum...
Others with resid
Anyway cutlers resin is a fine substance .
Two types are good to have on hand . One more fluid and one less fluid with more filler . You can also use animal hair to strengthen it when it's in a large mass as a filler. Like in a tulwar handle for example . Fine hair like cat hair is very good . I've seen aborigines uss kangaroo fur from the belly as is very fine and fluffy in winter.
People used flock. Fine fabric cuttings or lint too. Cotton wool as well would be fine.
Natural resins work great if made correctly.
The ratio of wax is important as to much it's to soft and to less it's brittle.
