Old 11th January 2024, 02:58 AM   #1
phil.reid
phil.reid's Avatar
Default European sword PL with Islamic? markings to guard
Friends just shown me a sword he picked up in Bali/ Indonesia, shop keeper said it was Dutch, has a small crowned PL ( Paul Luneschloss?) to the brass knuckle guard and what looks like Islamic? Siamese script to cross guard. Any thought appreciated.
phil.reid is offline   Reply With Quote
Old 11th January 2024, 05:57 AM   #2
Phil,
Please post a full length picture of the sword, as required for all translation requests. Thank you.
Ian.
Old 11th January 2024, 08:25 AM   #3
phil.reid
phil.reid's Avatar
sure, ill remember that for future, full length photo, think blades a period refit, you'll see tang pins been removed
Old 11th January 2024, 08:30 AM   #4
phil.reid
phil.reid's Avatar
handle, note drilled for tang pin
Old 11th January 2024, 02:55 PM   #5
This is of course an example of the ubiquitous 'briquet', which is the common infantry sidearm used so widely throughout European countries in the early into mid 19th century.
However, this example is profoundly unique in the history it holds.
According to J.P.Puype "Blanke Wapens", p.74, #108.
This is an infantry saber No.2 (M1819) which is indeed a briquet following French model ANIX (1801).
The tang button is apparent in the example shown.
The crowned PL must be some sort of regional acceptance mark, especially with the crown. If not mistaken Luneschloss was later in the century (not that this pattern did not remain in use)...and in my impression used the initials PDL in marking blades (often in oval cartouche).
As noted, this was from Bali, which, while most of Indonesia's population is Muslim, Bali is 87 % Hindu. These markings appear to be Sanskrit characters.
Perhaps though a Dutch weapon, this example was issued to someone in a local levy or police unit?
Old 15th January 2024, 06:17 AM   #6
Was it something I said?
Old 24th January 2024, 10:28 AM   #7
Radboud
No, you pretty much summed up the sword well.
Only thing I will add is that the Crown over PL is likely an inspectors stamp. The auction catalogue for the Dutch Army museum sale lists such an inspectors stamp (but doesn’t show an example) so it is quite likely to be a central rather then regional mark.
Old 24th January 2024, 01:10 PM   #8
Thank you so much Radboud! and I appreciate your confirmation on the marking as well as always for your sincere courtesy in responding to my post. I thought my analysis after finding what I thought would be helpful after some time researching would at least perpetuate other examples or some sort of onward discussion. If Phil is still around.....I was hoping I had not framed my wording in some manner that would have been unintentionally offensive. Things seem to get pretty touchy these days.
Very best regards,
Old 24th January 2024, 07:53 PM   #9
Radboud
While I haven't built a catalogue of images, these briquets (with Dutch origins but found in Indoneasia) do show up on Facebook sword groups from time to time. Usually they have been worked very hard and are fairly worn out.
In the context of things, this is not really surprising. Indoneasia, at least until recently, being a largely agricultural society must have found these briquets very handy tools to have around.
As for the sword Phil's friend has aquired, looking closer at the blade, I suspect that it originally came from a Dutch m1820 infantry officers sword, which was an identical copy of the British 1796 Pattern infantry officers sword.
I personally doubt the replacement was done 'in period', but it would have happened during the 'working life' of the sword. Most likely the briquet blade had become so worn from re-sharpening that to get the remaining utility out of the handle someone matched it with a broken officers blade.
Even with the shortened blade, the sword shown would still make a perfectly adequate slasher.
Old 25th January 2024, 04:17 AM   #10
Thank you again Radboud!
It seems the 'briquet' was one of the most ubiquitous patterns of simple other ranks hanger with its fully cast brass ribbed grip hilt in Europe, with most countries apparently having their production virtually all the same.
While these seem to have been used everywhere, and over long period from end of 18th well through the 19th c.
In my earliest days of collecting, I had Claude Blair's "European and American Arms" (1962) as one of my first arms books. I found one of these at a swap meet, and to my naive eyes it looked like a pirate cutlass! Then browsing through the late Mr. Blairs book, he had a drawing of one of these and captioned as a British 'foot artillery gunners sword'.
It was not until decades later that I discovered there was no such pattern, but these direct copies of the French briquet were apparently privately produced in small numbers. These seem to have been furnished to private units that were in effect 'home guard' paramilitary type groups.
While certainly most of what must have been staggering numbers of these simple weapons must have been produced, relatively few seem to ever turn up. Most were likely instant smelter fodder for the brass, but occasionally these turn up in odd circumstances.
Such as this Spanish colonial anomaly, which is composite with a briquet hilt, three bar cavalry guard and cut down Spanish dragoon blade in an ersatz effort to create an 'espada ancha' presumably.
As Phil had noted, apparently the sword in original post has similar (but less dramatic) circumstances.
Old 26th January 2024, 12:18 AM   #11
werecow
werecow's Avatar
What is the length of the blade Phil? It seems somewhat short for a spadroon blade (also the fuller looks wider than the ones on the m1820s I've seen - but I've only seen a few).
EDIT: Pictures for comparison. Not entirely sure if this one is Dutch, though.
Old 26th January 2024, 05:09 PM   #12
In my post #10, I showed the hilt of a briquet hilt, morphed into a composite 'espada ancha' with addition of three bar cavalry hilt and notably shortened Spanish M1728 dragoon blade. In the colonies of New Spain in the rugged frontera of North Mexico, repurposing of everything, weapons included, was of course common.
This seems to compare in kind with this briquet example shown from Bali, using a blade from other sword, shortened for wear or use more in the effect of a hanger.
Attached shows blade of the example I showed in post #10 , clearly a shortened dragoon blade.
