Old 20th July 2023, 08:58 PM   #1
wildwolberine
wildwolberine's Avatar
Default New bolo - dahong palay & leather cleaning advice?
New bolo! Kind of an impulse buy but I’m really pleased. Very similar to one i just posted (http://www.vikingsword.com/vb/showthread.php?t=28986). Xasterix kindly IDd that knife as a sinanbartolome profile from Laguna province, Luzon. Different maker’s mark (a “B” instead of a horizontal “P”), and the blade profile is more of a dahong palay?
Carabao hilt, through-tang (peened over), brass ferrule. There’s a tiny hole neatly drilled through the hilt, it must be for a lanyard as it couldn’t be insect damage). Leather sheath with attached belt. Thin, tapered blade. It does seem to have a chisel grind but it’s thin and hard to tell.
These are before-cleaning pics. Will clean the blade with WD-40 and 0000 steel wool and treat the horn with Hooflex. That’s duct tape residue on the leather. Any advice on removing it?
Age probably midcentury? Thanks!
Dimensions: 56 cm overall length, 41 cm by 4 cm blade.
Last edited by wildwolberine; 20th July 2023 at 10:40 PM. Reason: Added notes on blade grind
wildwolberine is offline   Reply With Quote
Old 20th July 2023, 11:31 PM   #2
RobT
RobT's Avatar
Default Bail?
Hi wildwolberine,
Does the hole in the hilt go all the way through? I ask this because, from your photo, it would seem to be drilled where the tang is. If it doesn't go all the way through, then it might have been drilled for a metal bail.
Sincerely,
RobT
Old 20th July 2023, 11:38 PM   #3
Try Goo Gone adhesive remover; it's orange oil based.
Old 21st July 2023, 02:11 AM   #4
wildwolberine
Hi wildwolberine,
Sincerely,
RobT
Yes, it’s drilled through. Looks like it’s just below the tang.
Old 21st July 2023, 02:13 AM   #5
wildwolberine
Thanks! I think I have a bottle somewhere. I ordered a bottle of glycerine saddle soap, I may give that a shot first.
Old 21st July 2023, 06:22 AM   #6
Default YMMV
Doubt the glycerine saddle soap will remove the mastic maybe soften it; try the goo gone after the saddlesoap.
Leather Therapy is a very good product for preserving suppleness and preventing drying and shrinkage.
Tags
bolo, laguna, luzon, philippines
