Old 12th December 2021, 07:29 PM   #1
Athanase
Athanase's Avatar
Default Origin of a pendok
Hello
I bought a lot of Keris with some spare parts including this metal pendok.
It may be mamas because the metal is a bit thick.
I would like to know which region is this pendok from?
Old 12th December 2021, 08:06 PM   #2
Jean
I would guess Java North Coast from the lenght (38.5 cm), curved & asymmetric shape at the top, and the decoration located in the center part only. Other opinions are welcome!
Old 12th December 2021, 08:48 PM   #3
In Central Jawa during the 1970's to 2010's most keris literate people whom I know & knew attributed this style of pendok to Banyumas.
As Jean has pointed out, it does have some indicators that could perhaps place it elsewhere, however, although North Coast blades are sometimes longer than than Central Javanese blades, these larger North Coast blades can be found in dress other than North Coast.
Similarly, a central panel of ornamentation is not unique to North Coast pendoks, it can occur in East Jawa, Ngayogyakarta & Solo pendoks too; it is much less common in Solo pendoks.
The type of central panel ornamentation that is common in North Coast pendoks, and that I have only seen in North Coast pendoks, is where the pendok has a very short central panel only a few inches long.
This pendok has a lis, the soldered or rolled collar at its mouth. This could weight origin towards the East of the North Coast, but it can also occur in a Banyumas pendok.
EDIT
One other possibility:- Palembang pendoks can have a pendok like this too.
Old 13th December 2021, 11:35 PM   #4
Athanase
Athanase's Avatar
Thank you very much for your answers Alan and Jean.
