Hi, anyone has experience that why new keris will have forge crack?
Depends on the type of crack Anthony, but common causes in forged work are material, ie, iron & steel, that is known as "hot short", in other words it does not forge easily and is subject to cracking under the hammer.
The second very common cause of a perceived crack is called a "cold shut". This occurs when the material is not at optimum temperature to achieve a weld, and/or the surfaces to be welded are insufficiently clean and/or a flux has not been used where it was necessary. A cold shut is not really a crack, but it often looks like one. |
#3 | |
My pleasure.
You can also have perpendicular cracks to the edge, that can be identify by a too hot quench of the blade.
JBG, I believe that if you care to test the base cause of this type of longitudinal crack you will find that it is evidence of a cold shut, the stresses of heat treatment merely expose this cold shut.
