Should I leave the blade as it is or should I try to clean it ?
Why I ask: I am afraid of damaging or even removing the yellow coloured ( gold painted?) curved stripe... Thank you for your advice ! Highly appreciated |
Hi Gunar,
It look like an Algerian knife (razor?). And yes, please clean the blade and polish up a little bit (not too much) the brass handle. Don't worry, the brass inlay is deep enough so there is no danger to remove it. Regards, Detlef |
Thnx a lot ! I have been told origin to be central Asia.
It's total lenght is 28 cm , unfortunately no scabbard |
Hello GP,
Nice knife! While I do not know this particular type of knife, the style and decorations seem typical Algerian to me as well. I have a couple of Flyssa swords with similar decorations. The golden decoration is most likely some bras inlay. I would also recommend moderate cleaning/polishing. The inlay should not be damaged if polished gently with grit 1500 (or just with polishing paste). Last edited by mariusgmioc; 13th July 2020 at 04:55 PM. |
Thnx a lot gents for the cleaningtips and the determination of its origin !
As Detlef and Marius have indicated, this is very much Saharan, probably Algerian, and seems related to the bou saadi knives but the motif as also noted of the 'flyssa' variety. There are as might be expected, considerable variations of these Saharan edged weapons, and this appears 19th c. into early 20th. Its always hard to say as these traditional weapons remained in use for generations in these tribes.
The motif is related to the type seen on the flyssa, which seem to have a combination of linear talismanic oriented theme along with often somewhat personalized devices. I would as always recommend restraint, stabilize any corrosion but try to keep as much patina as possible (personal taste). |
#7 | |
Time for me to atudy the flyssa as this is terra incognito for me.... So thnx again ! |
