Old 15th November 2019, 07:13 PM   #1
mahratt
mahratt's Avatar
Default Rare Indian Shield
Indian shield. Probably the early 19th century.
Old 17th November 2019, 02:35 PM   #2
mariusgmioc
mariusgmioc's Avatar
I have a Katar with similar koftgari.
The shield may be wootz...
Old 17th November 2019, 03:59 PM   #3
mahratt
mahratt's Avatar
You guessed it, Marius.
Shield of wootz.
Old 17th November 2019, 04:03 PM   #4
Jens Nordlunde
Jens Nordlunde's Avatar
Yes, Marius could be right, that the shield may be of wootz.
What are the 'nails' at the edge of the shield?
Is the decoration inlay or koftgari?
I have a katar, Rajput North India 18th century, with more or less the same floral decoration, but as floral decoration in many variations/combinations have been used over a very long period, this does not mean much.
Old 17th November 2019, 04:04 PM   #5
Kurt
Kurt's Avatar
Hi Mahratt,
I think 18 century.
I'm sure it's from wootz, it would be worth trying an etching.
Kurt
Kurt is offline   Reply With Quote
Old 17th November 2019, 04:24 PM   #6
mahratt
mahratt's Avatar
Originally Posted by Kurt
Hi Mahratt,
I think 18 century.
Kurt
Thank you, Kurt!
The collector, from whom I bought this shield, also said that it was the 18th century.
But I decided that it was made a little later.
Old 18th November 2019, 02:48 PM   #7
Kubur
Kubur's Avatar
Thank you, Kurt!
For dealers and collectors end of 19th c. means 1900
so i guess that early 19th c. means late 18th c.
From the photos the decoration is clearly koftgari.
Old 18th November 2019, 05:11 PM   #8
mariusgmioc
1. If it is wootz, then most certainly is 18th century up to worst case scenario early 19th century.
2. The paddings may be and most likely is later, 19c replacements.
Now, how do you know it is wootz? Can you discern the watering?
If yes, then I would definitely try etching the whole shield (not easy task).
If not, then I would try etching the whole shield anyhow to give it the natural aged patination.
Definitely a very nice piece! Thank you for sharinng!
