Old 11th September 2018, 07:21 PM   #1
sirek
sirek's Avatar
Default Keris panjang for comment
I was lucky to added this keris panjang to my collection
total length of 69cm/27,1” -the blade without pesi 56,5cm/ 22.2”
a nice keris was hidden under a lot of rust and dirt, a blade without pamor en with a square pesi I think the middle part of the gandar is made of horn
I will welcome any and allcomments about this keris,
sirek is offline   Reply With Quote
Old 12th September 2018, 07:10 AM   #2
Nice example Sirek.
I'm not surprised to see no pamor as that seems normal for most older examples of these.
The squared off pesi seems pretty unusual though.
Is the hilt wood or horn?
Old 12th September 2018, 08:59 AM   #3
Jean
Nice old kris indeed, congratulations!
I think that the hilt is made from black horn (see chip at the base). The blade & scabbard may not be originally matching. You could do a bit better on the cleaning process as there is some residual rust.
Old 12th September 2018, 10:38 AM   #4
sirek
sirek's Avatar
cleaning is not finished yet, but clean enough to show him in advance
and i also believe that the hilt is made of horn
Old 13th September 2018, 02:40 PM   #5
I am surprised we aren't getting more comments on this squared off pesi. I certainly isn't unheard of, but it is unusual.
Old 13th September 2018, 02:42 PM   #6
Also wondering what folks think of the "mendak" in place. It seems too small to refer to as a pendokok. It seems out of place in this ensemble and if this were mine i would probably seek to replace it with a proper pendokok.
Old 13th September 2018, 05:29 PM   #7
sirek
sirek's Avatar
David I think you're right, this model would be a better choice.
I have tried to search in old threats, but a square pesi is not much discussed in this forum,
Old 14th September 2018, 05:22 AM   #8
Paul B.
Paul B.'s Avatar
In addition to David's comment:
an example of a squarish pesi and I have had / seen a few more.
PS> What about Sirek's 'even' greneng, they seem unusual to me ? Worn off ?
Paul B. is offline   Reply With Quote
Old 14th September 2018, 08:52 AM   #9
Jean
The blade from Sirek looks very old. Squarish pesi are found on antique Javanese Jalak Budha blades but from the pics of this panjang blade I would rather called it a flattened pesi than squarish. I own one gana hilt for a Sumatra kris with a rectangular pesi hole, see pic.
Old 14th September 2018, 01:32 PM   #10
Yes Paul, i had assumed the greneng are simply worn down over time.
Old 14th September 2018, 01:37 PM   #11
Well Jean, i agree that this pesi isn't actually "square" which is why i keep referring to it as "squared off".
Your gana example is nice, though the particular photo you posted does not actually reveal the rectangular hole. But i certainly do believe you.
Old 14th September 2018, 08:25 PM   #12
Jean
Ha-ha, I have rounded the pesi hole since I bought it
The cross section of the hilt is oval so I am not fully sure that it was originally fitted on a kris, but rather on another weapon.
Old 26th October 2018, 12:49 PM   #13
sirek
sirek's Avatar
I have found a right selut that fits better,
