Old 22nd August 2018, 01:51 PM   #1
Anthony G.
Default For the keris and wood makers community
Dust and Noises*
DEBU dan SUARA BISING
Dust from metal and wood works are common in the workshop. It can cause cancer because your body absorb the dust over the long period.
Debu dapat menyebabkan kanker, karena tubuh akan menyerap debu dalam jangka waktu panjang.
Loud noises from sanding and drilling damage your hearing over long period of time.
Suara keras dari proses penggerindaan dan pengeboran bisa merusak pendengaran dalam jangka waktu panjang.
What To Do?
Apa yang harus dilakukan?
Clean the work area with a vacuum cleaner or a broom.*
Secara rutin bersihkan are akerja dengan penyedot debu.
Use a mask during the work and sweeping the workplace. Mask should be change regularly.*
Gunakan masker selama bekerja dan sapulah tempat kerja. Masker harus diganti secara berkala.
Wear earpiece to protect your ear from damage.*
Gunakan sumbat telinga untuk melindungi telinga anda.
Old 4th September 2018, 01:02 AM   #2
rasjid
Hi Anthony,
I do hope some people relay the message to carver/maker also. Most of them in remote area and some dont have the time to read this forum. Very good message with indonesian text as well.
Thank you.
Rasjid
rasjid is offline   Reply With Quote
Old 4th September 2018, 06:18 PM   #3
Anthony G.
Originally Posted by rasjid
Hi Anthony,
Thank you.
Rasjid
Hi, I have sent the soft copy template to a few friends in Sulawesi, Java and Malaysia etc and request them to distribute it in hardcopy to the empu/pande and makers whom they knew.
