Old 7th August 2018, 04:28 PM   #1
Default Bone Grip Mahdist short sword:
Just received this short sword, blade 22.5 in. tip to guard in a straight line, about 2.2 in. wide at the base, 2mm thick at the guard. weighs around a pound ex-scabbard. The grip is bone, guard and pommel cap is horn. peened tang. The scabbard is thin leather covered in crocodile skin. peened tang. Islamic etchings both sides near the grip, changing to a pattern of three snakes with tails near the tip.
I am assuming it is from the Sudan area & possibly Mahdist rather than Indian as the previous owner assumed...
Anyone care to comment? or have a similar one, etc? Thanks for any further info, in advance... (I have the dagger version, straight blade, bine grip in same style, sans scabbard or curved partners.
Old 7th August 2018, 06:31 PM   #2
thinreadline
thinreadline's Avatar
I would say the croc scabbard indicates Sudan rather than India
Old 7th August 2018, 06:45 PM   #3
You are the second to confirm my assumptions.
Old 7th August 2018, 07:19 PM   #4
TVV
TVV's Avatar
It is Sudanese, and the etched blade shows the considerable influence Persian arms from the late 19th century had in Sudan.
Old 8th August 2018, 06:57 AM   #5
Helleri
Helleri's Avatar
Scabbard cover material definitely looks right for young crocodile. Weirdly wrapped though. Hard to tell if it's a lower under belly and upper tail or half belly and side cut. Is it continuous (is the dark bit toward the tip a separate piece or tissue connected to the rest)?
Old 8th August 2018, 07:31 AM   #6
The dark bit at the tip is a separate 'chape' piece over the end. a bit thicker & less smooth than the rest on one side. The sewn seam is on the side, inside the curve, (along the spine). No seam on the edge side, so the main bit was all one piece. The croc skin is on both sides. That lighter main part could well be 'belly skin'. The chape part has what appears to be a ridge like I'd expect over a spine near one sewn edge. Skin is very dry, bit shrunken. Looks like it was put on wet as a tube & slid over the inner leather bit.
Any Ideas on what could be used to treat it to prevent cracking? the blade tip pokes out the end, close to a centimeter, so the chape bit could use a chape.
