Old 29th May 2006, 04:43 PM   #1
Nagawarrior
Nagawarrior's Avatar
Question Fijian Club?
I bought this club as an African club. Thats just what I thought it was until recently, when a dealer told me that this is a Ula. Now I'm confused. What is the consensus here?
Nagawarrior is offline   Reply With Quote
Old 29th May 2006, 08:46 PM   #2
I do not think it is African. Very nice. Could be from Papua?
Old 29th May 2006, 08:48 PM   #3
IainN
IainN's Avatar
This is indeed an ula from Fiji. Nice example, often these have carvings around the shaft where it meets the head. Yours looks to be a very workman like example. These are a throwing club.
[image rehosted to save other folks' bandwidth, orig. source here (scroll down): http://www.janeresture.com/oceania_ethnology/fiji.htm]
IainN is offline   Reply With Quote
Old 29th May 2006, 10:24 PM   #4
Mapico1
Sorry but this is no Ula but a stirr spoon from Kenya or Tanzania.
I have seen them many times offered on ebay as CLUB?????(with questionmarks because "club" sounds better than "spoon")
Mapico1 is offline   Reply With Quote
Old 30th May 2006, 04:28 AM   #5
Nagawarrior
The seller said either a club or food masher/spoon. Ula sure sounded much better. "If wishes were horses then dreamers would ride." You sound pretty sure about the "spoon". The Ula determination came from a dealer that specializes in African items. Thanks you for your insight.
Old 30th May 2006, 05:39 AM   #6
fearn
Anybody who's been thwacked by someone's kitchen spoon (or a frying pan) knows there's some overlap between kitchen implements and weapons.
Nonetheless, this isn't an ula. The one posted by Louieblades is.
I don't have the reference with me, but there are three different names for the types shown by Iain (the ula is #178 on the right). The ula is a short throwing club supposedly thrown like a knife (so that it rotates end over end) and designed to hit handle first (to concentrate the force). Allegedly. There's a long argument about this on the old Vikingsword forum from around 2003.
My 0.02 cents,
F
Old 30th May 2006, 09:35 AM   #7
drdavid
As a kitchen implement it looks more like a lemon juicer
DrD
Old 30th May 2006, 01:55 PM   #8
IainN
IainN's Avatar
I am currently selecting the crow to eat for supper. Looking carefully at the photos there are few things that should have tipped me off, 1) the texture and patina are consistent with something from a dry dusty climate and 2) the wood looks almost pithy in the one photo of the head, which contrasts with the harder more tightly packed grained woods that ulas seem to usually be made out of. Quick assessments never make for a good i.d.
Nice to know what these things are if they come up frequently on Ebay.
Old 30th May 2006, 02:08 PM   #9
BluErf
BluErf's Avatar
Haha! That's a good one!
A general (and possibly stupid) question about these clubs - looking at the relatively thin shaft on some of these clubs, how hard can one swing them (assuming they hit the target) before they break?
Old 30th May 2006, 02:08 PM   #10
Mapico1
Here's the spoon I have in my collection.It was brought back 5 years ago from the Tanzania/Kenya region.
Old 30th May 2006, 03:55 PM   #11
fearn
Hi BluErf,
I'll be interested for anyone to post measurements. Since I've been making staffs and canes for a while now, and reading about a bunch of clubs, I can give you the "it depends" answer now. Here's what it depends on, so far as I know:
Most weapons of any sort typically have handles less than 2" (5 cm) in diameter, simply because very few humans have a hand that can hold something thicker in a firm grasp. This includes things like sledge hammers and mauls, which can weigh 2-4 kg (5-10 lb) and have wooden handles.
Many clubs, staffs, etc. weigh between 2-5 lbs (1-2 kg, roughly), which, if you think about it, is the weight range of typical swords. I suspect that this is sort of an optimal range for weapons in general, being light enough to wield for an extended time, light enough to move dextrously, yet heavy enough to cause damage.
The basic point is that clubs seem to fall in the range of weights for all weapons, including axes, hammers, swords, spears, and maces. We seldom worry about handle failure in these tools, even though the handles are seldom more than 1" thick.
To give some idea about the relative strengths of woods, a yew longbow 1" wide and 1/2" thick would probably have a draw weight in the 50-100 lb range. a round "bow" that was 1" by 1" would probably have >100 lb draw weight for yew and for many woods. If you think of a club handle as a short, stiff bow, it looks like a 1-1.5" thick handle is thick enough to handle the forces its user would apply to it. Personally, I suspect that a club handle would only fail if there was a defect in the wood, due to rot, insect damage, or cutting across the grain of the wood. However, I would not recommend stress testing a century-old club, since wood does deteriorate with age...
My 0.02 cents,
F
Old 30th May 2006, 04:41 PM   #12
THROWING CLUBS DON'T NEED A THICK HANDLE AS BEING THROWN DOSEN'T PUT THE STRESS ON THE HANDLE THAT HOLDING IT AND STRIKING WITH IT WOULD. THAT BEING SAID, THE ULA CLUBS FROM FIJI ARE MADE OF A VERY DENSE HARD WOOD THAT IS HEAVIER AND STRONGER THAN LIGHTER WOODS SO PROBABLY WOULDN'T BREAK IF YOU STRUCK WITH IT. THEY WERE USUALLY CARRIED STUCK THRU THE BELT GRIDLE AND SEVERAL WERE OFTEN CARRIED THEY WERE THROWN FIRSTALONG WITH SPEARS. THE WARRIORS THEN CLOSED IN FOR FIGHTING WITH LARGER CLUBS AND SPEARS. I WOULD ASSUME THEY WERE USED IN AMBUSH ATTACKS ALSO AS THAT TYPE OF HUNTING WAS VERY COMMON (THEY WERE CANNIBALS).
THE CLUB PICTURED IN THIS POST HAS A HEAD WITH BLUNT EDGED STRIKING EDGES AND THE WAY IT IS CUT WOULD REDUCE THE WEIGHT OF THE CLUB. THESE TWO FACTORS WOULD REDUCE ITS EFFECTIVENESS AS A WEAPON AND IF IT IS MADE OUT OF LIGHT SOFTER WOOD WOULD ALSO POINT TO IT BEING SOMETHING OTHER THAN A WEAPON. FORTUNATELY WE HAVE A MEMBER WHO HAS AN EXAMPLE AND THE KNOWLEGE TO GIVE US A POSITIVE ID ON THIS ONE. SO WE CONTINUE TO LEARN!
Old 30th May 2006, 05:41 PM   #13
Do you think Martha Stewart could start a new line of kitchen implements?
Old 30th May 2006, 06:28 PM   #14
Mapico1
I checked my data and the spoon is GOGO tribe from Central Tanzania.
Ad your service...
Old 30th May 2006, 06:57 PM   #15
fearn
I dunno Ariel,
Was Martha Stewart convicted of a felony or a misdemeanor? If a felon, she really shouldn't be introducing a line of combat-ready kitchen utensils--she'd get arrested for weapons possession, for one thing.
Thanks Mapico--now my question is, how does one use this "spoon?" In a noncombat situation, I mean
F
Old 30th May 2006, 11:39 PM   #16
Nagawarrior
Ad your service...
Thank you very much Mapico. I really appreciate the help with this one. I might not really want to hear the truth, but it is how we all learn. I hope I'm not alone in learning the "hard" way. Man, was I happy when I was told this was a Ula. Now I just have to look in another direction and find the importance of this object in tribal daily life. I would love to understand how this "spoon" was used. I hope you can share more about it Mapico. Thank you so much again.
Stephen*
Old 31st May 2006, 02:19 AM   #17
Lew
Lew's Avatar
Stephen*
Well I heard this spoon was used by the wives of the that tribe to club their husbands over their heads when they insulted the wife's cooking or made a nasty remark about their mother inlaw.
Lew
Old 31st May 2006, 05:02 AM   #18
Nagawarrior
Lew
Very funny Lew. I'm feeling better about my purchase already. For some reason I'm picturing an African version of the "Honeymooners". Ralph saying "one of these days Alice, straight to the Moon, and Alice saying, " you just try it Ralph and I'll hit you with my spoon-club"!
Old 1st June 2006, 11:38 AM   #19
Mapico1
Hi again,latest info on tupperware and other kitchenalia.......
Spoon is used to make butter....spoon pressed in a bowl a little bigger in diameter.The lobs make it possible to let through the butter while pressing.
That's why the spoon smells......like out of date butter.
Old 2nd June 2006, 03:08 AM   #20
Nagawarrior
I actually tried to smell the spoon Danny. My wife thought I had lost it. I didn't smell anyting, but the spoon is old.
Got any photos of the tribes people to post? Can you recommend a book about these people so I might learn more?
Thanks for all your help. I really appreciate it.
Stephen*
Old 2nd June 2006, 11:34 AM   #21
Mapico1
Hi Stephen,
here a book I can recomment,the spoon is NOT in it but many statues,masks,stools,musical instruments,maps,etc.....
Book has 520 pages,German language,cheap(I paid only 30 euros for it 10 years ago)
