Old 19th September 2017, 02:54 PM   #1
thinreadline
thinreadline's Avatar
Default Cleaning rusty Indian chain mail suit .. advice sought
I have a potentially nice full coat of Indian riveted chain mail with most of its kapok padded liner intact . It is rusty but perfectly sound . I would like to both conserve it and enhance its appearance for display. Do any members have any tips ?
Old 19th September 2017, 03:58 PM   #2
Kmaddock
Kmaddock's Avatar
Hi
Lovely item well done on acquiring this item
Can you separate metal from the cloth liner
if so dry ice blasting is perfect for removal of rust without destroying platina
see below
https://en.wikipedia.org/wiki/Dry-ice_blasting
regards
Ken
Old 19th September 2017, 04:35 PM   #3
thinreadline
Originally Posted by Kmaddock
Hi
see below
regards
Ken
no it would not be practicable to remove the liner , sadly
Old 19th September 2017, 05:25 PM   #4
estcrh
estcrh's Avatar
You have a zirah baktar / zirah bagtar (mail and plate shirt. The lining is rare but most probably in bad condition. I know of only two reliable methods, chemical and electric rust removal. I have used the electro-rust removal method on a badly rusted riveted mail shirt with great results.
http://www.vikingsword.com/vb/showth...hlight=electro
Old 19th September 2017, 06:27 PM   #5
thinreadline
It is not badly rusted just overall light surface rust ... my aim is to stop further rust rather than to bring it back to shiny newness ...... any less drastic suggestions anyone ?
Old 19th September 2017, 06:57 PM   #6
estcrh
estcrh's Avatar
If it has red rust it has to be treated, red rust is active. The methods I mention will not bring it back to "shiny newness", that would take sandblasting or tumbling, acid etc...something a bit more aggressive.
Old 19th September 2017, 06:58 PM   #7
estcrh
estcrh's Avatar
Hi
see below
regards
Ken
Ken, have you used this method on mail armor yourself?
Old 19th September 2017, 07:25 PM   #8
Kmaddock
Kmaddock's Avatar
Hi Estcrh
No not used method on chain mail
I have used on a set of French breastplates, the red rust came off leaving the metal behind rust free but platina intact, You have great control with the dry ice as it uses shock freeze to loosen the rust as well as abrasives.
I was able to leave the leather straps on the breast plate and not damage them at all. The big benifit is no mess of sand or other abrasives as the carbon dioxide just sublimes away.
Quiet expensive but I had contacts😀
Ken
Old 19th September 2017, 08:18 PM   #9
thinreadline
it is not red rust it has old brown rust .
Old 19th September 2017, 10:33 PM   #10
estcrh
estcrh's Avatar
If it is a patina then that is different than rust.
Old 19th September 2017, 10:34 PM   #11
estcrh
estcrh's Avatar
Hi Estcrh
Ken
Thanks Ken, I learned something new!!!
Old 20th September 2017, 07:57 AM   #12
thinreadline
basically it is dirty with an ingrained layer of old brown rust powder and dirt .When that is rubbed off the appearance is so much better ... but how to do this on such a scale and should I be using wax or oil , soft cloth or abrasives or what ?
