Old 17th December 2016, 06:55 PM   #1
Cerjak
Cerjak's Avatar
Default Swiss cantonal riffle ?
This riffle has a heavy octoganal barrel
Caliber circa 18 mm
Total weight is about 7 kg.
An interesting detail: the barrel has a bayonet slot for military use.
Any comment on it would be welcome.
Best
Cerjak
Old 17th December 2016, 07:17 PM   #2
Hi Jean-Luc
There you have a Swiss target rifle, as you may see by the precision additions; reinforced multigroove rifling, set (adjustable) trigger, 'schützen' type butt plate and a block for an windage adjustable front sight ...not a slot for a bayonet
Old 17th December 2016, 10:23 PM   #3
Fernando K
Dear namesake
I do not see any connection between the block to the right of the barrel and the front sigth. It looks like some kind of bayonet. The drilling in the bar is for some form of fastening.
Affectionately. Fernando K
Old 18th December 2016, 09:23 AM   #4
corrado26
corrado26's Avatar
This is a privatly made Swiss rifle made after the design of the ordnance rifle M 1851, which was the first military rifle in whole Europe to have the small calibre of 10,5mm. The rifle shown was made by Siber Brothers at Lausanne/CH with a calibre of 18mm for private use. It has a block for adjusting a bajonett right of the muzzle, which was boltet by aids of a spring, whose clutch engaged in the hole of the block.
corrado26
Old 18th December 2016, 01:07 PM   #5
Default What am i missing ...
I fully understand your surprise at my assumption that the barrel side block is not for lodging a bayonet but, i didn't think i would have to doubt the description of this rifle by a well credited house, which reads as follows:
A .700 CALIBRE SWISS PERCUSSION TARGET RIFLE BY FRERES SIBER A LAUSANNE, NO. 133, CIRCA 1845 with heavy octagonal twist multi-groove rifled barrel fitted with adjustable back-sight and with a block on the right of the muzzle for a windage-adjustable fore-sight, engraved breech with an eagle above a numbered oval, case-hardened tang, signed case-hardened flush-fitting lock, set trigger, highly figured walnut full stock, iron mounts comprising spurred butt-plate, trigger-guard, three ramrod-pipes, the rear extending to form a rest beneath the stock, and two sling swivels (patinated), two vacant German silver escutcheons, horn fore-end cap, and horn-tipped ramrod 89.0 cm; 35 in barrel The brothers Jean Frédéric and Jean François Charles Siber are recorded working together in Lausanne circa 1845.
Old 18th December 2016, 01:27 PM   #6
Cerjak
Cerjak's Avatar
Dear Fernando ,
Please se the below pictures for swiss riffle with bayonet slot, some times even in reliable auction houses small omissions are possible.
Fenando k and Corado thank you for your comments.
Jean-Luc
Old 18th December 2016, 01:59 PM   #7
Parfait .
Old 18th December 2016, 02:14 PM   #8
iskender
Default sniperrifle ? " cantonale ordonnanz "
dear gentlemen ,in my collection i have many rifles of this type ,ranging from the flintlockaera pre 1800 till the late ones made with percussionlocks. the privat guns made for shooting as a hobby at that time have no bajonet and can reach gigantic size . the ones with a bajonet-holder are from a "Scharfschützen-Kompanie". at that time there was no central production of rifles in switzerland, these guns are mostly made by a local gunsmith or orderd in belgium /liege. there a even many of them with "damascusbarrels" there will be a good chance to find a fitting bajonet for this rifle! greetings iskender
iskender is offline   Reply With Quote
Old 18th December 2016, 07:05 PM   #9
Cerjak
Cerjak's Avatar
Default Carabine vaudoise mod 1842-50
Dear Iskender,
Thank you for your comment.
After some researchs in found some interesting informations about similar examples.
It seems that it could be a mod 1842/1852 so before the mod 1851.
Also I think that this riffle has a damascus barrel .
Best
Cerjak
Old 18th December 2016, 09:41 PM   #10
iskender
Default parfait !
Originally Posted by Cerjak
Dear Iskender,
Best
Cerjak
bonsoir cerjak , the missing bajonet together with a original leadersccabard has a standard price around 150 sfr in switzerland.there are many for sale now because the people who collected " Kantonale Ordonnanz " till 1848 are dead and the prices are very moderate on swiss items now ! ( i am the next generation also dead soon ) bonne soirée encore iskender
Old 19th December 2016, 03:54 PM   #11
Cerjak
Cerjak's Avatar
Hi iskender,
I found this model and I think that it could be the good model for my riffle.
SUISSE
Baïonnette à queue pour carabine modèle 1838 du Canton de Vaud.
Lame triangulaire poinçonnée au talon.
Longueur lame : 50,3 cm - Longueur totale : 57,8 cm
Best
Cerjak
Old 19th December 2016, 04:18 PM   #12
iskender
Default " stichbajonett "
Hi iskender,
SUISSE
Best
Cerjak
hello cerjak , this looks good ! congrats ! a military rifle with the bajonet missing is always somehow frustrating. iskender
