Old 14th August 2015, 05:07 PM   #1
castellum aquilonis
Default "Ancient" Ottoman (?) Ramrod : Age ?
I have this also for quite some time and thought it looked like a tool to remove bullets "out off" a person ;-)
Does anybody have an idea, how old it could be.
31cm
castellum aquilonis is offline   Reply With Quote
Old 14th August 2015, 06:11 PM   #2
Oops--no attachment with this one! OK, now we do.
Old 14th August 2015, 08:20 PM   #3
kahnjar1
kahnjar1's Avatar
Default Old Medical Instrument?
Just a guess....I do not think this is a ramrod. As you suggest it looks like something to remove "foreign matter" from ones body. An old medical instrument maybe? I am assuming that the prongs are metal?
What is the purpose of the threaded piece in the middle? Does it, or did it, screw into the other piece?
If this IS a piece of medical kit it would be getting up to 200 years old IMHO.
Stu
Old 14th August 2015, 08:30 PM   #4
castellum aquilonis
Default Link
http://www.vikingsword.com/vb/showth...ghlight=ramrod
Old 14th August 2015, 09:26 PM   #5
stelio
stelio's Avatar
Its a ottoman ramrod ,made in end of 18th century. I think it has lost half case and has go out the tweezer.
Stelios
stelio is offline   Reply With Quote
Old 14th August 2015, 09:52 PM   #6
ward
look up suma you will find enough complete ones to identify
Old 15th August 2015, 06:27 AM   #7
kahnjar1
kahnjar1's Avatar
Default ??
Not sure I understand the comments above.
If this is a ramrod missing it's end, then what is the purpose of the "tweezer"?
Same question...if it is a ramrod, why is there a thread in the middle of what is left? Surely if it is the end which is missing, then the thread would be there and not in the middle?
These are not a familiar item to me, so I am asking to learn about something new.
Stu
Old 15th August 2015, 12:21 PM   #8
stelio
stelio's Avatar
Stu
Hello Stu,
The are several types and each has different things when the were not in batle.
Other is a ramrod with tweezer[photo 1. Tweezer ramrod] .The ramrod use from warriors to bake food in fire,like a knive,for smoking tool[photo 2. Warrior firing with grill at the cigarette]
Stelios
Old 15th August 2015, 12:37 PM   #9
kahnjar1
kahnjar1's Avatar
OK I see. The "ramrods" were used for different purposes depending on what was inside them?
So going back to the first pics, the ramrod shown here has a thread in the middle which does not appear to screw into anything. The "tweezer" is at the end, but there is no thread there to attached the hollow???rod into which the tweezer fits.....so how does this item become a ramrod?
Stu
Stu
Hello Stu,
Stelios
Old 15th August 2015, 12:55 PM   #10
stelio
stelio's Avatar
This piece between is the case the half which put upside down . I think I put it there to help the pressure when I took the sphere from the barrel as they did some work had to be stable. I think the opinion of Kubur and Rick would be very helpful .
Stelios
Old 15th August 2015, 01:55 PM   #11
Pukka Bundook
It still appears something like a ball/bullet extractor to me, but I'm no expert!
It looks like the bit in the centre could be reversed and screwed into the handle part.
If the 'tweezers' are spring-loaded, (made of spring steel) they will expand as the centre tube is slid upwards towards the threaded part, and as the tube is slid back down to-wards the tweezer tips, the spring pressure is increased and they will grip an object securely.
Richard.
Old 15th August 2015, 02:43 PM   #12
An Ottoman suma.
See also here: http://www.vikingsword.com/vb/showpo...15&postcount=9
Old 15th August 2015, 05:30 PM   #13
Kubur
Kubur's Avatar
Stelios
I have nothing more to add, it's crystal clear.
Best wishes,
Kubur
Old 15th August 2015, 05:40 PM   #14
rickystl
Hello all.
Looks like it is in some what excavated condition. I don't think this was a Suma rod. Does not seem to be a provision at the rear for a neck throng. But there is a hole for a throng (or something) down the lower portion. Which would likely preclude this being used for loading a pistol. It looks like there is a piece missing from the lower section that may have threaded in the middle ?? But other than the tongs, I really can't figure this one out. But it's sure an interesting item.
Stelio: Thanks for the pic!! Never seen that one before. I'll add that to my library.
Rick.
Old 15th August 2015, 06:14 PM   #15
Kubur
Kubur's Avatar
Ah! this time I will disagree with Rick.
It is a suma rod, in a very bad condition and one piece is missing.
http://www.vikingsword.com/vb/showth...highlight=suma
And I will add your pic to my collection too, thanks Stelios.
Old 15th August 2015, 09:26 PM   #16
kahnjar1
kahnjar1's Avatar
Stelios
NOW I understand. Thank you
Stu
Old 16th August 2015, 01:45 AM   #17
stelio
stelio's Avatar
Rick see the ramrod of Kubur and certainly will see similarities with the photograph at the beginning of our conversation .
Stu on balkan area in 19th century none of the objects do not throw in the garbage if something seems tool could be done even if spoil . Rick and Kubur If you want there are more photos go to facebook. The name of page in facebook is fustanella painting.
Stelios
Old 16th August 2015, 03:50 AM   #18
rickystl
Hi Kubur!
I stand corrected. Thanks for the Link to that photo. You're right. It was originally a Suma Rod, that looks to be in excavated condition. That loop on the side of the shaft tells me it was to assist in un-screwing the lower portion with the thumb. My error. Good catch. I agree.
Actually, when I think about it, I don't know what else it could be, LOL
Rick.
