Old 14th April 2015, 12:49 PM   #1
BANDOOK
Default UNIDENTIFIED INDO PERSIAN OR ARAB SWORD FOR COMMENT
Measures: 99 cm long (out of sheath).
NOT SURE IFS ITS MIDDLE EASTERN OR INDO PERSIAN SWORD,PLS CHECK THE MARKINGS ON THE SWORD
REGARDS RAJESH
Old 14th April 2015, 02:29 PM   #2
Kubur
Kubur's Avatar
Hi Rajesh,
Your guard is very similar to some military khyber knifes.
Look this old thread
http://www.vikingsword.com/ubb/Forum1/HTML/001976.html
The blade looks also very Indian.
So for me, your sword is Afghan / Pakistani.
All the best,
Kubur
Old 14th April 2015, 02:37 PM   #3
Definitely not Pakistani: only after August 14, 1948:-)
One of the late 19-20 century Afghani military sabers, with British influence.
Also: please note the handle that is definitely not of a usual "khyber" form, but rather an imitation of the Russian regulation shashka pattern 1881.
Conceptually a schizophrenic "dog's breakfast" example, but unquestionably 100% genuine.
The ultimate reflection of the Great Game.
Old 15th April 2015, 04:10 AM   #4
BANDOOK
THANKS KUBUR AND THANKS ARIEL,GOOD INPUTS
Old 15th April 2015, 01:01 PM   #5
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Salaams, The stamp looks Turkish? ....Ottoman.
Bandook you have PM...
Old 16th April 2015, 03:39 AM   #6
BANDOOK
THANKS IBRAHIIM,CHEERS
Old 16th April 2015, 08:39 PM   #7
spiral
The Afghan army imported massive amounts of Turkish weaponry many decades ago. That's why there so many Afghan marked WW1 German bayonets etc.turn up there.
But without a translation of the stamp, its hard to say which language using Arabic script is stamped on that blade.
Was the blade once pipe backed possibly?
Old 16th April 2015, 08:53 PM   #8
Tatyana Dianova
An Afghani military sword with whole metal hilt and a Khyber blade - one may find weirdest combinations in this part of the world!
Old 16th April 2015, 09:05 PM   #9
mahratt
mahratt's Avatar
I think this is Afghanistan.
Old 16th April 2015, 10:21 PM   #10
spiral
Indeed Tatyana! Nice example!
They {The Afghan military} brought in weapons from everywhere, the also mixed matched component's & they also copied them as well!
And that's not even mentioning what the indigenous tribes created & mixed & matched.....
Old 17th April 2015, 09:12 PM   #11
Norman McCormick
Norman McCormick's Avatar
Yup, my example.
Norman.
Old 17th April 2015, 09:21 PM   #12
This is a most interesting example of variations of 'Anglo-Afghan' type arms which evolved in Afghan armies after the 2nd Anglo-Afghan war (Treaty of Gandamak, 30 May, 1879). While the Afghans had been developing a degree of 'westernization' in their armies with British subsidy much earlier, the Russians in the beginnings of the 'Great Game' were also trying to effect diplomatic relations there.
With this confluence, numbers of arms from these countries began coming in, and this influx of course continued well into the 20th century (obviously these conditions prevail into present times).
Amir Abdur Rahman Khan after the 1879 treaty became the de facto ruler under British suzerains, and with their subsidies continued industrial advance, in 1887 establishing the Mashin Khana arsenal in Kabul. Under British advisors the production of arms took place here, mostly with firearms but certainly including edged weapons in degree.
Most commonly seen are the Afghan swords sometimes termed 'regulation' types for the Afghan army, most of which seem to have been produced in the 1890s. These have characteristic pierced sheet steel knuckleguards with parallel openings (resembling typical guards on a number of European forms and British). At the top are also the complex 'swans neck' terminals next to the pommel. (see attached)
In the case of the posted example here, the pommel has an interesting cleft feature, which I would attribute to the forementioned Russian influences. It is worthy of note that a number of shashka like swords are present in Afghan context.
This blade is of a form known as 'quill point' well established in Germany early 19th c and often present on British cavalry sabres. It continued in German use well through the 19th c.
In 1893, Germany covertly sent representatives into Afghanistan to expand the arms factories. As the multi channeled heavy blades on the Afghan 'regulation' type swords seem quite German in quality, it begs the question , perhaps these quill point blades were produced for Afghan use as well?
I would say this is an Afghan military sabre of latter 19th century . It does not seem to have been produced in Mashin Khana as the notable mark is not present.
Old 17th April 2015, 09:38 PM   #13
Jens Nordlunde
Jens Nordlunde's Avatar
Very well done Jim.
Jens
Old 17th April 2015, 09:55 PM   #14
spiral
Years ago when I had a couple of these to hand, I discussed them with Robert Wilkinson -Latham because the steel & grinding was unlike anything Ive seen on any other Afghan weapon.
He & the German experts he then consulted were of the opinion they were clearly Solingen made.
The Afghan temple marks on some blades are just ownership or inspection marks As there are also many English made Lee Enfield bayonets that carry the same hot stamp...{As well as the Afghan made ones..}
Old 18th April 2015, 12:27 AM   #15
Very well done Jim.
Jens
Jens, thank you very, very much!!!!
Old 18th April 2015, 12:33 AM   #16
These marks were used by the regime, and primarily applied at the Mashin Khana, as described in the article on this establishment in Man at Arms (2009). This factory was in operation producing many of the Enfield rifles and accompanying bayonets in the 1880s in their assembly, with some components brought in under British supervision Mr. Wikinson-Latham would of course be well versed in these circumstances, and it seems he indicated to me at one point that many of the bayonets had been produced en masse in Solingen for makers in England to meet voluminous quotas.
Old 18th April 2015, 05:07 AM   #17
There was an article by Mahratt here on on this Forum postulating existence of an evolution of the Afghani khybers toward the "regulation" pattern illustrated by Jim.
I was always uneasy with the term "evolution", since the same or a very similar pattern was worn by an Afghani representative at the Treaty of Gandamak, well before the appearance of its alleged "evolutionary predecessors" marked with the Mashin Khana " Mazar-I- Sharif" stamp.
But be it as it may, the conclusions of the current topic strongly veer toward the existence of an unstructured hodge-pudge of Afghani weapons at the time of massive penetration of the Afghani military tradition by the Western influences: handles, D-guards , blades.
I fully agree with Tatiana: in that part of the world one finds contemporarily existing weirdest combinations of native Afghani tradition, British examples of various ages and patterns, German imports and Russian "regulation" pattern were thrown together without any centralized overarching idea. The same is happening even today, with the Khyber knife and AK-47 happily coexisting side by side. No evolution here: Afghanistan is an island that time forgot......
Old 18th April 2015, 07:34 AM   #18
spiral
Thank you Jim, that's fascinating!
spiral
Old 18th April 2015, 12:27 PM   #19
Regarding the Afghan sword which has often been deemed a 'regulation' pattern for their army in the 1890s (these were often present even as late as the '3rd Afghan War' in 1919) this is perhaps a misnomer in the true sense of the term regulation.
I recall when I first acquired one of these in the 1990s, and at that time they were not well known among most collectors. Many of them were somewhat fancifully identified in many cases, however the one I acquired was properly described as 'Afghan'. The deep stamp in the blade was then regarded as from the 'arsenal at Mazir I Sharif' . This was of course incorrect as I found in later years, and while the representation was of the Masjid at Mazir I Sharif, the stamp was used as a dynastic state symbol and applied at Mashin Khana.
I recall research on my sword and the excitement of seeing the photo (attached) by John Burke (in "Northwest Frontier" by Arthur Swinson, 1967)of officials at the signing of the 'Treaty of Gandamak, May 26,1879 .
In this photo, second from the right is General Daoud Shah, Commander in Chief of the Afghan Army . .....and he is indeed wearing a sword whose hilt is remarkably like these later 'regulation' swords.
This set forth a long search to find more on the significance of this apparent forerunner of the 'regulation' form we now know as the Mashin Khana products of the 1890s (mine is dated 1896). The objective of research on this type of hilt was to determine when and where they might have originated.
Much as in the use of the term 'regulation' for the Mashin Khana swords is a misnomer in degree, the terms development or evolution are perhaps in similar category with regard to classifying these weapons in categoric sense. As has been noted, these regions have been the center of geopolitical strife into ancient times, and even more intensely in recent centuries. In this volatile context and with so many influences present, I would say that we are examining a spectrum of variations in these weapons rather than trying to establish a distinct line of evolution or development.
In my opinion the study of these weapons is primarily using key historic data, provenance examples when available, and analysis of associated clues including art and cultural materials to assess examples on their own merits.
With this we can establish a reasonable image of the details pertaining to these, and where consistancies are found, these may be considered in degree a 'development'.
Old 18th April 2015, 03:06 PM   #20
mahratt
mahratt's Avatar
Dear Ariel. I used the term "evolution" is applicable to a specific group of items produced in a relatively short period in Kabul Mashin Khan. And my assumption confirms the stamp. I recommend you read the article again. Perhaps in the version in Russian, it will be more accessible for you.
Old 18th April 2015, 08:00 PM   #21
spiral
They earliest known & properly dated piece is not always the earliest that existed....
\for the earliest mk.1 kukri Ive ever seen was dated 1903, most prolific collectors have never seen one dated before 1904. most kukri collectors have seen ones dated 1915...
But there may be ones unseen by us that's dates to 1901 or an unmarked by identical pioneer from 1805...
Without a paper trail from the time its hard to be certain... :
Old 18th April 2015, 09:10 PM   #22
Exactly, and that's why most prudent authors always regard their work as pretty much 'open ended', and encourage further research and investigation. One well said statement once heard was '..the thing I like best about history, is that it's always changing!'.
While much of the discussion in threads here may often be centered toward new acquisitions and sharing these examples between collectors and dealers, we very much encourage discussion and fact finding. We never know, and on some occasions one of these might yield key clues we have been seeking to reveal exactly these kind of 'Kodak moments.
The knowledge base here, as well as the constant exposure to examples and widespread experience in observing them makes our pages the perfect 'field labratory' for such studies.
Old 18th April 2015, 09:33 PM   #23
spiral
Exactly, and that's why most prudent authors always regard their work as pretty much 'open ended', and encourage further research and investigation. .
Exactly indeed Jim..
I try to learn everyday.. I am a student...
