Old 12th February 2015, 02:54 PM   #1
bathala
bathala's Avatar
Default unique krag belt
just wanted to share this belt. seems to fit the 30-40 krag ammo. patterns on the textile as research cuold be bagobo, moro wars? opinions welcome
bathala is offline   Reply With Quote
Old 14th February 2015, 06:11 AM   #2
estcrh
estcrh's Avatar
Any history on it, were was it found etc.
Old 14th February 2015, 07:08 AM   #3
Will M
Will M's Avatar
You may want to consider 30 US (30-06) and the British.303.
Then there are the Mauser 7mm and 8mm.
With looped belts they can hold a variety of cartridges, this one in 30 cal or so.
Old 14th February 2015, 07:14 AM   #4
Will M
Will M's Avatar
This is a good link to the arms the Moros used
http://www.morolandhistory.com/05.pg...o_firearms.htm
Old 15th February 2015, 04:28 PM   #5
bathala
bathala's Avatar
just came up at a local auction. i noticed the patern seemd framilliar and a friend olso concluded the textile pattern. the diamond shapes mostly uses by the bagobo, though the yakan olso uses the same 4 diamond patterns
Old 15th February 2015, 11:55 PM   #6
estcrh
estcrh's Avatar
Good link, thanks!
