Old 6th December 2014, 08:20 PM   #1
Martin Lubojacky
Default Shi sword for comment
I am enclossing a few pictures of the sword I have acquired recently. I think it is not long, not short - the total length (in the sheath) is 78 cms, length of the blade is 59 cms. Interesting is that the blade is relatively wide - it is 4 cms wide at the base (I thought Shi swords were narrower). Thickness of the blade is 1.2 - 1.3 cm at the central rib. It is heavy and it could be used as a machete (again surprising for me).
The sheath is two-coloured and I would like to know, if this has any implication, or if the reason is purely aesthetical (till now I saw only one colour Shi sheaths).
Fur was wrapped around the sheath at its end and at its mouth. I removed it temporarily to check the state of the wood, but, very probably, I will not put it back, since the state of the fur is bad (it is losing hair). Does the fur has any deeper sence, or is it just decoration ? Any comment is warm welcome.
Martin
Old 6th December 2014, 10:08 PM   #2
Hello Martin,
very nice Shi sword of good age. To sad that the fur is in bad state. I think that it is added for talismanic purpose. The two coloured scabbard is decorative IMVHO.
Old 6th December 2014, 10:54 PM   #3
Congoblades
Congoblades's Avatar
A two-coloured sheath is fairly common but usually the two-tone effect was obtained by metal wire.
Congoblades is offline   Reply With Quote
Old 7th December 2014, 08:30 AM   #4
There is something really I like about these and other swords from surrounding areas.
Old 7th December 2014, 12:20 PM   #5
Congoblades
Shi sword and dagger from my collection.
Old 7th December 2014, 01:09 PM   #6
This one was once in my collection: http://www.vikingsword.com/vb/showth...light=shi-havu
Old 7th December 2014, 04:32 PM   #7
A NICE SWORD THE FUR LOOKS LIKE RABBIT AND IF IT IS, IS NOT LIKELY TO HAVE BEEN SOMETHING HUNTED AND USED IN AFRICA. I DON'T KNOW IF WILD RABBITS OR HARE ARE IN AFRICA AT LEAST I NEVER SAW ANY. IT COULD BE SOMETHING ELSE AS THERE ARE PLENTY OF FURRY CRITTERS IN AFRICA BUT MOST I AM FAMILIAR WITH DON'T HAVE THE SOFT FEEL OF RABBIT FUR. IF ITS RABBIT PERHAPS THE SWORD WOULD BE BETTER IF IT IS NOT RE- ATTACHED DEPENDS ON HOW YOU LIKE IT BEST.
Old 7th December 2014, 06:56 PM   #8
Congoblades
Using fur on this type of sword is also not uncommon but used as belt or belt decoration. Probebly monkey fur.
Old 7th December 2014, 10:04 PM   #9
Martin Lubojacky
Thank you all for the comments. There are wild rabbits in Africa - I would say they are common. The fur could be monkey, too ( I think there is more possibilities). Congoblades, thanks for nice pictures - I did not see such "superb" styles of the Shi swords till now. It īs also nice o see the couple - dagger and sword in the same style. BTW, there are varieties (different handles etc.) - which other groups used this style sword (Tutsi ??) ?
Martin
Old 8th December 2014, 03:04 PM   #10
Congoblades
The one with fur and decorated scabbard should be Hutu - Tutsi.
These swords were worn to the rear of the head
