Old 22nd October 2014, 07:25 AM   #1
Martin Lubojacky
Default Which kind of steel is this ?
The blade (cca 60 cms long and originally very rusty), was mechanically cleaned, plunged into disodium salt of EDTA and again cleaned with a very fine steel brush, than cleaned in demi water and treated wit silicon oil.
I think the steel is not mechanical damascus, actually, I donīt know what to think about it. If I cleaned it too much deep, the structure(design) disappeared on some places (tip and near the tip). What is this ? I heard such design could be result of tempering (quenching), but I am not sure. (the handle is original except of the central rhomb rivet which is new).
Old 22nd October 2014, 08:38 AM   #2
ALEX
ALEX's Avatar
Martin, I do not see/think it has any particular pattern, although I see one weak streak, but hard to tell. extensive pitting and mechanical cleaning do weaken the pattern and make it harder to etch.
Old 22nd October 2014, 09:59 AM   #3
Iain
Iain's Avatar
I have to say it looks like mono steel to me, simply exhibiting aging due to exposure to dust/dirt etc.
Old 22nd October 2014, 12:56 PM   #4
The type is known to have a twist core centre within the very narrow fullers but nothing gives it away if it is there.
Old 22nd October 2014, 04:07 PM   #5
Oliver Pinchot
These blades are often layered, which etching may reveal. But it isn't an intentional pattern-weld. I'd leave it as is or perhaps clean lightly.
