Old 5th January 2005, 02:42 PM   #1
Jens Nordlunde
Jens Nordlunde's Avatar
Default The katars
Although I don’t intend to lecture anyone about katars, I think you should take good old Stone and have a look at page 347 #14, 16 and 19. These katars have blades from 70 to 80 centimetres, but they are still called katars. You should also have a look at the blades on the south Indian and the north Indian katars, they are quite different.
The long bladed katars suggests, to me, a slashing weapon, mostly likely used from a horse, especially when the hand guard is closed like on the gauntlet sword – only then it is a pata, not a katar. If you in an attack on horse stab a man with a pata, you will most likely get your arm torn off at the shoulder, be pulled off from the horse – or maybe both, be course you will not be able to free the sword from the man, nor will you be able to let go of the sword fast enough, and if you did/could, you would be without a sword, although I am aware of that they often had a saddle sword and a personal sword.
The south Indian katars with the broad, rather thin blades with only a small armour piercing tip are fairly sharp, and could be used both for slashing and stabbing, whereas the north Indian katars with thicker blades and big armour piercing tips were for stabbing, not for slashing in the same way as the south Indian katars.
Due to the heat the south Indians were not dressed as heavily as those from the north, besides mail shirts was an old tradition amongst the Moguls, but not used as much in the south.
In my opinion the north Indian katar was made for opening a mail shirt, and this was not needed in the south. The different ways they protected themselves, gave a need of different katar types.
The total length of the katars shown is, from the top 25 cm and 39 cm.
Old 5th January 2005, 02:48 PM   #2
Jens Nordlunde
Here is one from the south. Total length 48 cm.
Old 5th January 2005, 10:47 PM   #3
RSWORD
RSWORD's Avatar
Thank you for posting such lovely examples. I especially like the Tanjore example. The fullering is quite precise and I like the contrast between the blackened steel on the guard and the bordering koftgari'ed panels. Often on these the wootz patterning would be left visible in the fullers and the edges polished bright giving again a nice visual contrast.
Old 5th January 2005, 10:48 PM   #4
B.I
hi jens,
its strange that the most common of indian weapons is one that has never really been properly researched (apart from your own continuously valiant efforts). the dagger had not variated much in 400 years, from the mid 16th to the late 19th and for this reason alone, i think people are wary to take on the academic burden of written commitment. its form, as you say, differs from north regions to that of the south and this is understandable, given the different influences each region had. if you accept the weapon to be of hindu decent, then hundreds of years of influence from the moghul north and the sultanate south had imprinted the slight variations. these variations are indeed slight, if you discount the obvious difference of a handguard. people tend to assume that just the hooded katars are of the south and the plain 'H' shape grip is of the north. the hooded handguard seems to be a hybrid of the pata, or as i have speculated in the past, a development of an earlier weapon, of which the katar developed from as well. i say this is speculation due to no hard evidence, apart from crude or worn sculpture that hold strange weapons whose form seems to have not survived in real pieces. a type od standard H shaped katar existed in the south as well and this was a variant of the northern version, with subtle differences.
as for what is a katar, this is again down to the individual. i have always been of the opinion that i can call a weapon by any name if this name allows the person i am talking to to understand what i am talking about. i know others will disagree, but i have never held any interest in terminology, and have seen many discussions stop at this debate and go no further. i use the word katar loosely to refer to anything katar shaped that isnt a definate guantlet. this includes hooded katars of all lengths. it would be good to remember that egerton and hendley both spent many years in india (as well as cole, irving, watt etc) and held exhaulted positions with access to the many weapons of the time as this is where their passions lay. if they could not agree on terminology and they were there at the time, then it must make this unimportant today in the grander scheme of things.
back to the katars shape, the katars of the south (the unhooded ones) tended to have quite subtantial armour piercing blades as well. due to fashion and availability, european blades were widely used but they also used native blades as well. another point, especially as my passion is armour the moghuls and rajputs tended to wear a lighter style of armour, especially into the 18thC. miniatures rarely show heavy armour, even those of the 16th/17thC and it is thought that the miniatures showed silk gowns that were laced on the inside with chainmail. some of these exist in the reserves at the V&A. even deccani miniatures tend to ignore the heavy armour, although we know that heavy armour was used, especially in the south. the bikaner armour is evidence of this. for this reason, armour piercing was as important in the south, if not more so. the nature of the katar as a weapon (in any length) lends to a heavy force that would pierce through armour, maybe even without the swollen tip. as the links in armour tended to be butted into the 18thC and definately the 19thC, where armour was almost pointless in the advent of firarms as a more available weapon, the armour piercing tip would have been good, but not necessarily essential.
the make up of early armour shows a need to protect the upper torso against a thrust, and for this reason it was appropriately thickened, and in some cases, the chainmail was doubled over. i am guessing this wouldnt be necessary for a sword slash. again, the martial aspect is not my interest and so will leave that for others.
interesting to note the form described in the late 19thC (from the 'seir mutaqherin of the mid 18thC - translated by haji mustapha) who says of the katar -
'a poignard peculiar to india made with a hilt, whose two branches extend along the arm, so as to shelter the arm and part of the hand. the blade is very thick with two cutting edges, having a breadth of three inches at the hilt and a solid point of about one inch in breadth. the blade cannot be bent and is so stiff that nothing will stop it but a cuirass. the total length is 2 to 2.5 feet, one half of this being the blade.'
your insistance on bringing indian weapons forward is appreciated, as always.
Old 6th January 2005, 09:49 AM   #5
Jens Nordlunde
Rsword thank you for your answer. If you like Tanjore katars, then have a look here.
Besides the fish and steel pearls on the side guards, also notice the fish and peacocks at the top of the blade. Between the two cross ribs there are seven little wheels, which can turn, and in each of the cross ribs there is a steel ball rolling.
Hi Brian thank you for your answer, which I find interesting, also you give some good references. I can’t say that I fully agree with you, although I agree with most of what you write, and as evidence is hard to find, I will let the points where I disagree with you rest fro the time being.
Jens
Old 28th May 2014, 04:57 PM   #6
Jens Nordlunde
When looking for something else I found this old post, and as I am especially interested in the kater I have researched it a bit.
In an article written in South Indian Studies, vol. 25, 2009, I have taken it back to the 10th century in Orissa.
It seems as if it could have started in the South, although there is no evidence so far for this, and it could even be older, but further research will have to be done.
Jens
Old 28th May 2014, 11:10 PM   #7
russel
Hi Jens,
I love Katars, but only have two. They are hard to find in Australia (our weird customs regulations prohibit importing them).
I have tried to find a copy of your article: "How old is the Katar" but it isn't available without a journal subscription. Is there any chance you could make this available to Forum members?
Cheers, Russel
Old 29th May 2014, 10:41 AM   #8
Jens Nordlunde
Hi Russel,
I am sorry, but when you let one of these magazines publish an article you at the same time give them copyright.
I have noticed that I have made an embarresing error. In South Asian Studies no 25 the article published is Royal Katars of Bundi.
The article How Old is the Katar? was published in Arms and Armour, Vol. 10 no 1. Royal Armouries, Leeds. Sorry.
Jens
