Old 6th April 2019, 02:19 PM   #1
sirek
sirek's Avatar
Default madura patrem
From the box that I had bought ,
keris 1 (http://www.vikingsword.com/vb/showthread.php?t=24660)
keris 2: a keris madura patrem
Unfortunately with: a Ganja-missing but with a kul buntet and a square pesi
At first i thought the gandar had been repaired (through the black ring) but upon closer inspection it seems that it is a sort of kendit in the wood? It is no paint, on some points the wood structure runs slightly through the black.
sirek is offline   Reply With Quote
Old 6th April 2019, 02:34 PM   #2
Interesting patrem. I am especially intrigued by the pesi. Not only is it squared off, but the heavier bit right at base of the blade is something i have not seen before.
I am not yet completely convinced that the gonjo is missing. This might be gonjo iras.
Old 6th April 2019, 03:18 PM   #3
sirek
sirek's Avatar
I thought that the ganja had sat on the heavier bit right at base?
Old 6th April 2019, 05:42 PM   #4
I suppose that is possible, but since i have never seen this feature used a a means to lock a gonjo in place i can't really confirm nor deny such a possibility. Perhaps someone else has seen something like this before.
Old 6th April 2019, 10:15 PM   #5
David, the enlargement of the pesi at its base is in fact common and the gonjo does fit around it. A gonjo can be fixed in a few ways, you can file a key-way into the gonjo hole and drive in a key, or you can use a punch and expand the meeting faces of the gonjo and pesi, I will not go into the other ways. If you want to use either of these ways to fix a pesi, the enlarged base of the pesi and provision of a shoulder on the pesi assists fixing.
Sirek, the joint between the top part of the wrongko (atasan,gambar) and the bottom part (gandar) has been filled with a mixture of glue and sawdust, the wrongko was not originally intended for this blade and it was necessary to alter the angle of the gandar to atasan. Again, this is a pretty common fix, and a good fix, the cheaper fix is to fill the gap with button shellac.
Old 7th April 2019, 01:51 PM   #6
sirek
sirek's Avatar
thanks for the comment and the clarification,
