Old 10th February 2013, 09:49 PM   #1
regihis
Default Funj Kaskara - British Museum
The blade and guard of this Kaskara sword are made of steel and the handle of silver. A silk tassel with silver threads woven into it decorates the handle. The blade is in good condition, apart from one horizontal crack. It has maker's marks on one side, one of which contains the remains of a copper-alloy inlay that has been hammered into the groove. An Arabic inscription decorates both faces; one side reads: 'When he meets the enemies everywhere my sword will be the executioner' and the other reads: 'A man of glory and dignity is always the leader of his society'. Conservators from the Sudan National Museum in Khartoum and the British Museum worked together on the sword. A Sudanese conservator cleaned the silver handle and a British Museum conservator cleaned the steel blade, revealing the maker's marks.
The sword belonged to Nasir Mohamed, the Funj sultan from AD 1762 to 1769. The period leading up to AD 1762 was an unsettled time for the Funj dynasty. Despite the continued expansion of their territory, tension had been mounting between the rulers and their warrior aristocracy for several years. Rivals rose unsuccessfully against the Funj ruler Badi III in the early eighteenth century but successfully against his son Unsa III. Unsa's successor Nul (connected to the Funj through his mother) and his son Badi IV ruled peacefully for forty years. This ended when Badi was overthrown in 1762 by Mohammed Abu Likaylik, a rival commander. Despite nominal rule by the Funj sultans (including Nasir Mohamed) until 1821, the dynasty had lost all real authority.
Article: http://www.britishmuseum.org/explore...ern/sword.aspx
regihis is offline   Reply With Quote
Old 10th February 2013, 09:54 PM   #2
Iain
Iain's Avatar
One of my favorites!
In additional to the clearly visible sun and running wolf marks - I'd point out the sickle marks (often referred to as Genoese) applied in two sets of pairs, as seen in the last image.
If I'm not mistaken, this is the earliest complete kaskara documented.
Old 13th February 2013, 04:34 PM   #3
stephen wood
stephen wood's Avatar
..I think it must be one of the earliest. The picture, from 1821, shows a King of Sennar.
stephen wood is offline   Reply With Quote
Old 13th February 2013, 06:42 PM   #4
Not to be too obvious but does that mean that silver hilted kaskaras belonged to rulers?
Old 14th February 2013, 01:24 PM   #5
Iain
Iain's Avatar
I have always thought that in general only those of status could afford these do to the material used and the workmanship required. However I don't believe there's anything to indicate their use was restricted to rulers in any social sense. The means to own or commission such a hilt probably being the limiting factor - so there's no reason to think a successful merchant, a palace official or any other wealthy individual couldn't have owned one.
