Old 4th January 2013, 11:42 AM   #1
Taffjones
Default Tulwar for comment/discussion
Hi Guys
Comments welcome on this tulwar please. It has a thick blade of 6mm tapering down. with three fullers. What strikes me as unusual is the width of the blade which steps down in size about 15cm away from the hilt from 35mm before slowly tapering to its full width again. It shows old traces of koftgari work on the spine of the blade and the hilt area. It has various eye brow type markings along the blade. Its length across the curve from top of pommel to end of blade is 85cm.
Thanks
Darren
Taffjones is offline   Reply With Quote
Old 4th January 2013, 11:56 AM   #2
Taffjones
Two more photographs
Old 4th January 2013, 12:50 PM   #3
A.alnakkas
A.alnakkas's Avatar
Nice tulwar! I cant say much of them as I dont know alot about these type of blades. I had one very similar (minus the gold decoration) but sold it about 1 year ago.. The blades are certainly good!
Old 4th January 2013, 02:15 PM   #4
Henk
Henk's Avatar
problem solved.
Old 4th January 2013, 04:39 PM   #5
Jens Nordlunde
Jens Nordlunde's Avatar
I think you should try and research the hilt types from North-Northwest of India - you may find something useful.
Old 5th January 2013, 02:49 AM   #6
It is always difficult to get too specific on many forms of Indian arms, with the tulwar being a most notorious example. These hilts were widely used from areas where they were often produced, then often fitted with blades from equally varying regions, as well as foreign blades.
This type of hilt is typical of those of the NW in India as Jens has noted, with various centers of production in Rajasthan. The blade is distinctly Indian, with not only the ricasso on the blade edge, but the often seen stepped or latch back feature on the back. These triple fullers seem to be often seen on tulwars of later 18th-19th c.
The hardest part of classification is also establishing possible date. These traditional forms were used over long periods of time, so focus on the decoration on the hilt is a possible avenue to follow. The designs on this hilt remind me somewhat of 'cintamani' related devices, but only in a general sense. I am inclined toward Sind, and likely 18th into 19th c. but only as speculation. Similar type blades and hilts are among the swords used by the Talpurs as noted by P.Hayes (1971), but actually the hilt with knuckleguard is well known in Rajput, Sikh and Mughal use as well, so more specific attribution is unlikely without key inscriptions, marks or motif. The koftgari on the blade back is seen on much earlier blades in India, and remind me of another sabre I had which I always considered from Sind as it had a solid steel shamshir type hilt with tulwar quillons and langet. It had a British M1788 cavalry blade with koftgari applied at the forte very similar.
The curious 'eyelash' or seemingly shallow crescents seen on the blade do not seem part of any significant intent, but marks like these and the trimurti (three dots) found sometimes at what appear strategic blade locations are often compelling.
Not much help Im afraid, but wanted to add some of the kinds of details considered in researching these swords, and hopefully some ideas.
