Old 15th December 2010, 03:32 PM   #1
Atlantia
Atlantia's Avatar
Default Recipe for wood filler?
What do you guys use for filler on ethnic gunstocks if areas are missing or splits in old wood etc?
I've always made up my own rather than use a shop bought resin. Any recipes? I'm curious how others solve this problem without the results looking 'new'?
Old 15th December 2010, 05:23 PM   #2
kahnjar1
kahnjar1's Avatar
Hi Gene,
My collection now is basically, blades but at one time I had many guns. To repair/fill breaks etc I kept a supply of broken stock pieces and used suitable wood and colour to fill breaks. A useful way to "match" the colours is to use CONDYS (???spelling) CRYSTALS. Mix a VERY small amount of the crystals with water, which is all you will need. It drys brown and when dry, bone it with either a piece of smooth bone or even the round shank of a screwdriver. Amazing what it will hide in terms of new repairs. For broken horn or later plastic butt plates I used Epiglass Plastic Steel. Its black and when sanded and polished it does a great job.
With your current weather patterns be careful not to get wool fibres from your gloves mixed up with your repairs.
Old 15th December 2010, 05:36 PM   #3
TVV
TVV's Avatar
Gene,
I do not have many rifles and have not had to try it, but I have heard from a friend who has hundreds and according to him, the best way to do it is with sawdust and superglue. According to his instructions, you put a bit of sawdust in the area where the wood is missing, followed imemdiately by a drop of the super glue, which solidifies the small amount of sawdust in place. Then you repeat the process until the restoration is complete, and naturally, sand at the end. This would work on gunstocks that are of dark color (the glue turns the sawdust dark, regardless of its original color), and for small areas.
And to repeat my disclaimer - I have not actually tried it myself.
Teodor
Old 1st January 2012, 11:38 AM   #4
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Salaams Atlantia~ I liked this little thread so much I just had to make a comment.
A friend of mine swears by the superglue and sawdust technique and I commend it and the other workshop practices to Forum.
Ibrahiim.
Old 1st January 2012, 12:11 PM   #5
AJ1356
AJ1356's Avatar
I've seen some superglue and dust fillings, they are pretty good, to untrained eye. The method is pretty good, but I think something other that crazy glue would be preffered at lease by me. Crazyglue leaves a somewhat shiney residue, and is a bit messy, so maybe some clear wood glue would be better, I dunno have not tried it.
Old 1st January 2012, 09:22 PM   #6
I would think that epoxy would be a better filler than crazyglue.
Old 2nd January 2012, 06:21 PM   #7
fearn
Problem with epoxy, especially if you mix it, is it's hard to get all the bubbles out. Crazy glue is a little easier to keep the bubbles out of.
F
Old 2nd January 2012, 07:47 PM   #8
Never had problems with bubbles but whatever..............
Old 10th January 2012, 03:59 AM   #9
harimauhk
We used PVA glue and sawdust in high school...worked a treat. more recently I've used superglue and sawdust with good results.
harimauhk is offline   Reply With Quote
Old 25th January 2012, 11:56 PM   #10
trenchwarfare
trenchwarfare's Avatar
I use white glue. Elmers, Dollar General brand, doesn't matter. Remove the buttplate, lock, or whatever part is removable. "Borrow" some wood shavings/filings, and mix with the glue. Fill in the area missing wood, and let dry. The smoother you apply, the less sanding you have to do. By using wood from the affected gun, the color is an perfect match.
Old 26th January 2012, 06:40 PM   #11
TimW
TimW's Avatar
there is a filler available that is used to fill up holes in wooden floor boards. It is a transparant fluid (smells strongly / volitile). It needs to be mixed with sanding dust (saw dust is too coarse) and can be applied. The surface is slightly sanded afterwards. When using the same sanding dust as the original wood, the difference is hard to spot.
For smaller cracks i use superglue with our without sanding dust. Look for the fluid version that will soak in deeply and sand afterwards.
TimW is offline   Reply With Quote
Old 26th January 2012, 08:22 PM   #12
rickystl
Hi Gene! For filling fine cracks, I've found something that works better than Super/Crazy glue. It's called "ZAP" glue. There are a couple other competing Brands similar. They usually sell it at hobby stores. What I really like about this glue is that it is available in three different thicknesses. Thick, Medium, and Thin. Even the thick is fairly thin. The Thin is so thin, it seems to run thinner than water. I've even used the Thin in a hypodermic needle for very fine cracks to keep the crack from spreading. Use the Thin a little at a time. Let dry overnight and add more the next day, and so on till you are satisfied. Best stuff I've ever used for filling cracks. Rick.
Old 27th January 2012, 08:09 AM   #13
Atlantia
Atlantia's Avatar
Excellent thoughts and ideas everyone Thanks to all of you
