Old 11th January 2012, 09:22 PM   #1
Default Cannon changes Australia history ?
Have you guys seen the news ?
http://www.couriermail.com.au/ipad/....-1226241146851
Old 12th January 2012, 12:02 AM   #2
Matchlock
Matchlock's Avatar
Remarkable find indeed, especially if it is of Portuguese manufacture!
Michl
Old 12th January 2012, 02:01 PM   #3
That's precisely the point, Michl.
Portuguese style, no doubt, but ... Portuguese original manufacture or, cast in the West Indies ... Jawa, Sumatra, Malaca, under Portuguese supervision or later 'free lance' later copies, falling into the Lantaka area .
Let's see what the local museum says ... assuming they hold the final truth.
Old 14th January 2012, 02:15 PM   #4
cannonmn
Too bad the photos did not show the area just forward of the breech opening, as it appears to bear some type of raised symbol. One here is much larger and bears a kind of star with a button in the middle in that area, and I'm fairly certain it is Malaysian, or at least "South Pacific" in origin. Back to the young man's discovery, given the geography of the area, if I had to judge whether it is more likely that this came from say, Indonesia as opposed to Portugal, my money would be on the former every time.
This is an extremely small, light weapon of its type, smaller than I've ever seen before, and was probably that size because it was the largest such weapon that could be carried by some kind of canoe or very small vessel. This is not the type of vessel that would be capable of traveling from Portugel to Australia, but more likely one which could make the journey from Indonesia to Australia, if with great difficulty. I've seen quite a few much larger breechloading "pedreros" of cast bronze, similar in construction to the small one shown, and most seem to have bores in the two to three-inch range and weigh somewhere between 100-250 pounds. The young man's find looks to have something like a one-inch bore and probably weighs 20 pounds. I'll see if I can dig up a photo of the larger Malaysian one we have here (about four feet long, 1.5-inch bore, 60 lbs.)
cannonmn is offline   Reply With Quote
Old 14th January 2012, 03:17 PM   #5
The authenticity of this piece (as being Portuguese or not) doesn’t necessarily have be questioned by its small dimensions.
There were in fact small bronze ‘berços’ (cradles), cast in Lisbon, of the size fit to equip in batels (ships ‘multiuse’ auxiliary roaring boats) in disembarking operations and light enough to be carried by crew men in river exploits.
This recently found example might as well be a XVI-XVII century local interpretation of a Manuelin berço.
Attached is of such examples, cast in Oriental India between mid XVI and end XVII centuries, with a diameter of 1,5 cms and a cannon length of 97 cms. (excluding the cascavel).
Their ammunition was generally a lead bullet or a bamboo tube filled with small shot.
Still the authenticity of the one found in Australia is something to be discussed. This type of cannons, having joined the Lantaka family, were later (XIX century) developed into distinct purposes, as either operational or passive versions, the late being widely used as currency (cannon money).
Those bearing such examples in their hands are in a better condition to judge their purpose and originality.
Let’s see what those museum curators say about it … if only caring for the truth and not fearing to shake history concepts.
Old 14th January 2012, 07:02 PM   #6
cannonmn
Amazing.
Fernando, the photos you posted there are as close to what I'd call a "dead ringer" (identical) as you can get. I isolated and compared features of the boy's cannon to yours and they are an excellent match down to some small details. I don't know the size of the boy's discovery so didn't compare that, but that's not as critical as the contours.
Question 1: If you could clarify this perhaps in terms that an American would understand:
Please where is that in other terms?
Question 2: How do we know or how can we prove that it was cast in "oriental India?"
Question 3: Do you have any closeup photos of the small raised insignia just forward of the breech opening?
Question 4: Regarding the Thunder Mug which is serving as the stand for the long gun: As I'm sure you know that is a separate device for signalling, making noise, celebrating. These are still widely used in Italy, lined up by the dozens or hundreds, along a train of blackpowder. Were any markings noticed on that item? Do you know where it came from?
