Old 8th February 2012, 12:35 PM   #1
Atlantia
Atlantia's Avatar
Default Moplah Malabar Ayda Katti type chopper
Essentially this is an update, so read to the bottom!
First a big thanks to Chris, Gav, Stu, Jim, Dave and Richard for the help in the original thread about this chopper. I think that for clarity and to help with future searches I'm going to show my new findings here with links to the original sources.
Right, so here is the item in question:
Old 8th February 2012, 12:42 PM   #2
Atlantia
Atlantia's Avatar
Sorry for the multiple posts, it's going to be the only way I can set out the pictures.
Following the identification by those gentlemen mentioned above I took to google images to try and find a similar example I stumbled upon this chopper with similarites in the blade shape, which happened as it turns out to be from an old thread here.
Old 8th February 2012, 12:45 PM   #3
Atlantia
Atlantia's Avatar
...and in that thread, Jens linked to an old thread of Bill's showing this:
Old 8th February 2012, 12:50 PM   #4
Atlantia
Atlantia's Avatar
In that thread, Olikara comments on Bill's sword:
"Bill,
A very beautiful Katthi. Congrats.
This will be from the Moplah or 'Mappilai' people of Malabar. They are quite different from the Coorgis who are of Scythian and Hindu stock. The Mappilais are of Arab-Dravidian Muslim stock.
Coorg is adjacent to Malabar but not a part of Malabar. And very interestingly the Moplah rebellion of 1921 where the Moplahs rebelled against their Hindu landlords (Mostly Nair and Brahmin) was put down by the British who used their Gorkha levees to great effect. Moplah Katthis against the Kukris!
The Coorgis and Moplahs were never on the best of terms though. Tipu Sultan in order to subdue the ever restive Coorgis had a policy of settling Muslim populations from Mysore and adjoining Malabar into Coorg. Needless, to say after Tipu's destruction the Coorgis drove off most of these new settlers."
So, comments?
Old 11th February 2012, 02:15 PM   #5
Atlantia
Atlantia's Avatar
Is it possible that the initials are of the local dialect/script? What about the other way up?
Old 11th February 2012, 04:38 PM   #6
Jens Nordlunde
Jens Nordlunde's Avatar
Yes it is possible, but not very likely, as inscriptions are always read when holding the weapon. So should it be like you suggest, you should hold the weapon and then turn your hand, and that is not the way they would have done it.
Jens
Old 11th February 2012, 04:41 PM   #7
Atlantia
Atlantia's Avatar
Jens
hi Jens,
Thanks. You've got a lot of experience of weapons of the Indian subcontinent, what are your thoughts on this chopper?
Best
Gene
Old 11th February 2012, 05:04 PM   #8
Jens Nordlunde
Hi Gene,
Your Molaph is a nice one, it is something between a Molaph and a Adya katti, but still more on the Molaph side.
When Hendley was in India, at the end of 1800 he write, that the work of the Indian artists was declining, but that there were still some, which could master good quality.
Jens
Old 11th February 2012, 06:20 PM   #9
Atlantia
Atlantia's Avatar
Hi Gene,
Jens
Hi Jens,
Thank you.
It is definately in my 'to do' pile for a clean up.
Best
Gene
Old 11th February 2012, 06:25 PM   #10
Atlantia
Atlantia's Avatar
double post
