Old 17th August 2011, 12:03 PM   #1
levani
Default arabian shamshir?!
Your comments please
levani is offline   Reply With Quote
Old 17th August 2011, 12:20 PM   #2
AJ1356
AJ1356's Avatar
looks suspeciously Persian to me. I could not make out the writing unfortunately. pretty nice though
Old 17th August 2011, 03:26 PM   #3
Martin Lubojacky
A think the blade is Persian, hilt and mounts are typical for Syria
Martin
Old 17th August 2011, 04:11 PM   #4
Kurt
Kurt's Avatar
Martin
Hi Martin ,
I agree with you, is a correct assessment.
Best Kurt
Kurt is offline   Reply With Quote
Old 18th August 2011, 04:32 PM   #5
tom hyle
The use of a ferule or wrap that covers the upper lagnet seems to me a distinctly Arab practice that is also seen on kaskara. Is this seen on Pesian or Turkish hilts?
On kaskara (ie inland Southern Arab swords from Africa) I've seen the guard has an ordinary (if I may) tang slot rather than the feruling hollow center found on Persian and Turkish guards. Is this the case with Northern Arab swords as well?
Old 21st August 2011, 04:31 AM   #6
For me, the differentiating point is the orientation of the pommel: 90 degrees to the handle - Persian, bent down ( like this one) - Syria, bent up - Aravia proper.
Old 21st August 2011, 11:59 AM   #7
Martin Lubojacky
I think, as far as sword-hilt is concerned, typical for Syria are also small stars and dots on the handle
Old 21st August 2011, 12:39 PM   #8
A.alnakkas
A.alnakkas's Avatar
Yep, This is a syrian style hilt. There are 5 types of "shamshir" hilts used by arabs:
1- Najdi/Badawi hilt.
2- Shami or syrian style hilt.
3- Persian style, but with added wire typical seen in syrian and najdi.
4- Turkish style hilt (usually with wire added).
5- "Badawi" style hilt attributed to the coastal kingdoms of the gulf.
As for No.5 I mean a type that is very hard to tell apart from the typical najdi. The main difference is that the pommel on such swords is shorter then that of the najdi (similar to persian shamshir pommel) while maintaining almost every feature of the najdi hilt (riveted hilt slabs, Identical guard and wire wrapping + chain)
Alnakkas
Old 22nd August 2011, 12:08 PM   #9
levani
what about blade?
woots? sham?
can someone translate writing?
Old 18th September 2011, 06:52 AM   #10
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Originally Posted by levani
what about blade?
woots? sham?
Salaams, We think in the top cartouche its says dar amal.... made by... The rest is blurred but we expect the name of the maker... or the name of a famous sword maker often repeated and copied down the centuries... Regards, Ibrahiim al Balooshi .
