Old 20th August 2025, 01:03 AM   #1
Lead Snowstorm
Default Old handcannon with smaller breech
Greetings all - I recently obtained an old handcannon which appears to have some similarities to that discussed in this thread, c. 1350:
https://www.vikingsword.com/vb/showthread.php?t=12151
Pictures are attached below. It is mounted in a reproduction tiller stock. The caliber is approximately 4.4-4.5 cm; overall length of the barrel is about 29.2 cm. The breech (“pulverkammer”) is about 1/3 of the overall length. Interestingly, the touchhole appears angled slightly from the breech at the surface towards the muzzle at the inside. This merits further examination. I will try to get an X-ray of the barrel, but as I have access only to a medical-grade machine I may not have sufficient power to reveal any detail.
Lead Snowstorm is offline   Reply With Quote
Old 25th August 2025, 06:49 PM   #2
M ELEY
Hello and welcome to the Forum. I am a novice when it comes to these items and I know some of our old Forum folks that dealt with these extensively are unfortunately no longer with us. However, there are still a few out there and hopefully they will respond. I must say it is an amazing hand cannon and if you did the replacement work yourself, you did an amazing job! The angled touch hole does raise a few questions. I know with thunder mugs, the touch holes that had an angled 'pocket' for the powder/fuse were because they were signal cannon meant to be placed flat against the ground, thereby making the touch hole facing upwards. This cannon appears to be a true firearm with it's larger size, so I'm not necessarily suggesting it's a "mug", but again, maybe an expert will come through on this. Anyone??
Old 26th August 2025, 03:20 AM   #3
Lead Snowstorm
Most of the noisemakers I’ve seen required a flash pan (as you mention) to hold the priming charge - this one doesn’t have a pan at all. And I must also admit I’ve not seen one of those upright noisemakers with a narrower breech - usually they were swamped wider at the breech to enable them to stand up. So I do agree this one is most likely not a thunder mug.
I cannot take credit for the stock - it came to me that way. I definitely agree, whoever made it did a great job!
Old 7th September 2025, 11:01 PM   #4
Ed
Ed's Avatar
Lovely Hussite type hand cannon. Had my eye on one that was sold at auction then with a dealer in Florida.
ETA Definitively not a noisemaker.
Ed is offline   Reply With Quote
Old 8th September 2025, 01:28 AM   #5
Lead Snowstorm
I suspect that was this very piece - Czerny’s December 2023?
Old 9th September 2025, 03:56 PM   #6
Ed
Ed's Avatar
Yes but a dealer in Miami had it more recently. That where you got it?
Old 10th September 2025, 11:11 AM   #7
Lead Snowstorm
It is.
Old 10th September 2025, 01:29 PM   #8
Ed
Ed's Avatar
He is an old pal, you did good. Ever want to dump it call me.
