Old 10th September 2010, 09:30 AM   #1
Amuk Murugul
Amuk Murugul's Avatar
Default Bone Handle Removal
Hullo everybody,
Is there a simple way to remove a bone handle from a keris when it is filled and fixed to the tang with caulking compound/plaster (i.e. removal w/o damaging the pierced carving)? The last time I did it, it was so laborious.
Old 10th September 2010, 11:00 AM   #2
khalifah muda
khalifah muda's Avatar
Originally Posted by Amuk Murugul
Hullo everybody,
There 2 options:
a) soak the hilt intermittently in lukewarm water till the hilt loosen,
b) heat the blade from a distance till the hilt is loosen (most effective way that I've tried)
Another option which is quite risky, place the blade in between a thick book, put pressure on the book while trying to move the hilt bit by bit.
Happy trying.
khalifah muda is offline   Reply With Quote
Old 11th September 2010, 07:37 AM   #3
Amuk Murugul
Default SUCCESS!:)
Originally Posted by khalifah muda
There 2 options:
Happy trying.
khalifah muda,
Thanks for your help.
Now all I have to do is clean the white stuff off the nooks and crannies.
A pity that there are some minor chips off the scroll-work. I guess somebody has tried to remove it before.
