Old 25th November 2009, 08:48 PM   #1
Default Bolo Tusok
posted this one of mine on another board last year, someone just bumped it up, thought it was cool. i posted back with some more detail, and now thought i'd post here as well. this is a relatively new blade, i've had it for a few years but suspect it's been made this century.
the bolo tusok weighs 1.75 lbs. (780 gm) without the sheath. blade is roughly 1/4 in. thick at the guard, 1 3/8 in. wide at the guard, 1.5 in. at the first 'hump' on the spine and 1 5/8 at the hump nearest the point. thickness is distal tapered from the guard to the point. blade is 16 3/4 in. long. grip is 7 in. long, nicely figured very dense and dark brown wood with black stipes.
the bolo is allegedly a 'tusok', meant for stabbing, tho it's heavy and substantial enough to cut. very well made and full convex grind. it's signed,
looks a bit like a rearing cobra with two cuts across it. see attached. does anyone recognise the mark? i assume it is a contemporary maker in the phillipenes...
Old 26th November 2009, 01:38 AM   #2
t_c
It's the letter "A" in Baybayin (Phillipine Script), I don't know if has any special meaning on it's own....
http://www.eaglescorner.com/baybayin/symbols.html
t_c is offline   Reply With Quote
