Old 15th May 2009, 05:44 PM   #1
Mefidk
Default Help with sword ID
Hi folks, I hoped someone might be able to shed a little light on this piece?
This is one of three mystery (to me) pieces that I picked up in an auction lot a year or so ago. The grip is an old replacement with an old makeshift repair. The blade is 70cm long, overall lenght 84cm. The light and flexible blade has one large shallow fuller, is 32.6mm wide along most of its length and 3.3mm wide at the back at the base, terminating in a kilij tip. The guard looks to me like it might be Persian, and from the shape of the grip I wondered if the sword was of Persian origin, but I'm not at all convinced that the guard fits well with the rest of the hilt.
Thanks in advance for the help,
Chris
Mefidk is offline   Reply With Quote
Old 15th May 2009, 06:07 PM   #2
ALEX
ALEX's Avatar
Chris, the blade reminds me of 18th century European, (English?) pattern blade. The crossguard and hilt are likely later additions, and are of Persian form.
Old 15th May 2009, 07:31 PM   #3
Norman McCormick
Norman McCormick's Avatar
The blade looks like it's from a British 1796 Light Cavalry Sabre cut down from the normal length of approx 33 inches. Hope this is of some help.
Norman.
P.S. It would appear to have been modified from the hilt end rather than blade tip.
Old 16th May 2009, 08:59 AM   #4
Mefidk
Thanks gents that is a great help.
Having looked again at the blade with this idea in mind I do believe that you are have it bang on. As I understand it the 1796 saw a lot of use on the Indian continent so perhaps this is a captured blade quickly modified for local use. In any case I'm happy that the mystery is solved since Iwould not have figured this out myself for a long time, if ever.
I'll put up mystery no 2 later and see if it meets with similar success.
Thanks again
