Old 9th February 2014, 12:31 PM   #1
Multumesc
Multumesc's Avatar
Default SHIELD RESTORED
The old shield has been presented elsewhere.Now is mine.I restored and now looks better.I do not know what is written on it.He is shield before restoration.
Multumesc is offline   Reply With Quote
Old 9th February 2014, 12:47 PM   #2
Multumesc
Multumesc's Avatar
Shield after restoration.I want to help me with translating the text from the shield.Thank you very much.
Old 9th February 2014, 12:51 PM   #3
Multumesc
Multumesc's Avatar
And other pictures.
Old 9th February 2014, 01:29 PM   #4
Very good job you have done! The shield look very nice now. Which advice you have followed?
Old 9th February 2014, 02:51 PM   #5
Good question
Old 9th February 2014, 05:17 PM   #6
Sancar
Great work! Can you please post pictures of inner side of the shield?
Sancar is offline   Reply With Quote
Old 9th February 2014, 07:35 PM   #7
Multumesc
Multumesc's Avatar
The shield I put in a plastic box over it poured vinegar 9 degrees. Everyday you clean it with hot water from the sink with a plastic brush, then enter back into the tank with vinegar repeating this process for 7 days.In the last day after I removed the vinegar and I rinsed and cleaned with plastic brush, I rinse well .No is immediately as gloss metal. After a good drying I gave wire brush .After the treatment with vinegar were removed about 1mm layer of rust.Rust finding the bottom of the bowl with vinegar. Put vinegar to cover the shield.This process is not suitable for objects worn.Vinegar can attack some important details.The object is kept under control.
Old 9th February 2014, 07:44 PM   #8
spiral
Looks like a new one!
spiral
Old 9th February 2014, 09:07 PM   #9
Martin Lubojacky
Hi multumesc,
If you treat old metal with water, or water solution, water you use should be free of chlorine (destilled or boiled, at least). Otherwise, from the long time period point of view, it could be affected with inner corrosion (even after "relatively good" drying).
Martin
Old 10th February 2014, 01:33 AM   #10
AJ1356
AJ1356's Avatar
looks nice, It is Persian or Afghan. If you get better pictures of the text I could let you know what it says. There should be a marker to mark the begining of the text.
Old 10th February 2014, 08:47 AM   #11
Ibrahiim al Balooshi
Ibrahiim al Balooshi's Avatar
Salaams all..Please note ..that using hot vinegar is extremely dodgey... first it will take the paint off a door at 1000 yards !! and rip off rust like its not there... and if you slop it in your eyes ... well its a bit like battery acid. As already noted soapy water or perhaps coke-cola and continuous checking over short periods but please be advised on the agressive nature of hot vinegar!... I wouldn't normally comment much on cleaning methodology except to mention that it is the ethnographics we are after not the aesthetic or cosmetic technology...Though properly done it may be admired; you can't always put patina back.
Ibrahiim al Balooshi.
Old 10th February 2014, 12:30 PM   #12
Multumesc
Multumesc's Avatar
Still, I would like someone to help me with translating the text on the shield. Please and thank you very much in advance.
Old 10th February 2014, 05:57 PM   #13
Multumesc
Multumesc's Avatar
New pictures for translation. Photo1
Old 10th February 2014, 05:59 PM   #14
Multumesc
Multumesc's Avatar
PHOTO 2
Old 10th February 2014, 06:01 PM   #15
Multumesc
Multumesc's Avatar
PHOTO 3
Old 10th February 2014, 06:03 PM   #16
Multumesc
Multumesc's Avatar
PHOTO 4
Old 10th February 2014, 06:04 PM   #17
Multumesc
Multumesc's Avatar
PHOTO 5
Old 10th February 2014, 06:07 PM   #18
Multumesc
Multumesc's Avatar
PHOTO 6
Old 10th February 2014, 06:08 PM   #19
Multumesc
Multumesc's Avatar
PHOTO 7
Old 10th February 2014, 06:12 PM   #20
Multumesc
Multumesc's Avatar
PHOTO 8
Old 10th February 2014, 06:14 PM   #21
Multumesc
Multumesc's Avatar
PHOTO 9
Old 10th February 2014, 06:19 PM   #22
Multumesc
Multumesc's Avatar
PHOTO 10
Old 10th February 2014, 06:21 PM   #23
Multumesc
Multumesc's Avatar
PHOTO 11
Old 17th February 2014, 10:55 AM   #24
Multumesc
Multumesc's Avatar
We found that the shield was brought from Syria.I want you to help me with translate of the text.Thank you very much.
Old 17th February 2014, 02:08 PM   #25
AJ1356
AJ1356's Avatar
I asked for better pictures on an earlier post, if you can get me those I could translate it for you. The text is Farsi, I think I even know from which book. Just get me better pictures. Pictures of one word at a time wont help.
Old 18th February 2014, 06:07 PM   #26
Multumesc
Multumesc's Avatar
I wrote the text on the shield, for translation. Thank you very much.
Old 18th February 2014, 06:10 PM   #27
Multumesc
Multumesc's Avatar
PHOTO 1
Old 18th February 2014, 06:18 PM   #28
Multumesc
Multumesc's Avatar
Detailed pictures
Old 18th February 2014, 06:20 PM   #29
Multumesc
Multumesc's Avatar
Old 18th February 2014, 06:22 PM   #30
Multumesc
Multumesc's Avatar
