Old 18th April 2009, 09:47 AM   #1
Ascalon
Ascalon's Avatar
Default Moro keris ID
I bought recemment two moro keris, the first one look fine but I find the 2nd have a little size.the blade is cm. 44, approximately incs 16,9.
Can help me to identify these keris both, and in particular the 2nd.
1
2
Thanks
Ascalon is offline   Reply With Quote
Old 18th April 2009, 11:47 PM   #2
Congrats, #1 looks like a sweet 19th c. piece with a diminutive ivory pommel! Could you please post dimensions of the blade and a close-up of its base (taken from directly above - not at an angle)? I like the fullered blade - definitely worth trying a mild etch. The hilt has nice silverwork features; the braiding shows a bit of wear which apparently has been fixed with some glue (probably in recent times). No problem, just be a bit careful when handling this nice piece!
#2 seems to be a genuine Moro kris with laminated blade. I believe the blade is from Sulu and (possibly early) 20th century; workmanship may point to a local, village-made piece. The laminations at the tip are not typical: I think the length may be due to a shortened blade. The glue at the base of the hilt as well as the non-standard attachment/repair of the asang-asang (aluminium?) may hint at a recent "restoration" or even redone hilt or pommel. The pommel is weird (only vaguely resembling late 19th c. Junggayan hilts from Sulu) and the use of this style as well as ivory IMVHO doesn't seem to fit the lower quality of the blade; also the rattan wrap is later and was probably done when attaching the current pommel.
Old 19th April 2009, 12:06 AM   #3
The fiber wrap on this short one reminds me of tarred Italian Marline; often found in a sailor's ditty bag; it may all be newer stuff also .
Number 1 is nice .
Old 19th April 2009, 01:59 PM   #4
migueldiaz
migueldiaz's Avatar
Nice krisses! especially no. 1.
The style of the braiding and silverwork of no. 1 look very similar to the capture piece displayed at the US Military Academy's West Point Museum ...
Old 19th April 2009, 10:16 PM   #5
I agree with Kai on everything so far.
In fact, the 2nd kris reminded me of this early to mid 20c puppy:
www.oriental-arms.com/photos.php?id=1565
The blade of the 2nd could be Maguindanao.
Old 21st April 2009, 02:30 PM   #6
Ascalon
Ascalon's Avatar
Thanks for comments and the pic of west point museum.
Emmanuel
